Overheating mystery
  • BK544E34
    • May 2012
    • 172
    Overheating mystery
    94 530i. Has built motor. Irrelevant for this issue...
    Car was not warming up so I replaced the thermostat and the waterpump (it was leaking too) Now the car won't bleed and overheats. The car has had stop leak in it prior to my ownership. Can blow through the heater core, no problem.
    Car temp gauge will climb when giving gas and then will come back down with RPMs. Car has been bled with BMW Special tool vacuum bleeder, a Snap-on vacuum bleeder and has also sat with a spill free funnel and ran until it has warmed up. The heater is still blowing cold.
    Any ideas where I should go next?
    1999 M Coupe
    2014 X1 xDrive35i
    2000 P38A HSE
    1989 Lachs 4 Door
    Instagram: MCoupeKim
  • Aleksey
    • Feb 2011
    • 336
    Check / replace coolant temp sensor in the rear of intake manifold and one on passenger side of radiator.
    Also if this issue is happening right after you build your motor... have somebody else open up and check it after checking it with vacuume gauge for proper Hg which will tell you if something is wrong right away.
    Founder @ Maintenr. Take control of your vehicle maintenance.
    • BK544E34
      • May 2012
      • 172
      The motor has 76k and counting. Compression is good and leak down is <10% on all 8 cylinders.
      Will check the temp sensors, but the lack of heat leads me to believe that it would be an air pocket somewhere.
      1999 M Coupe
      2014 X1 xDrive35i
      2000 P38A HSE
      1989 Lachs 4 Door
      • FLG
        • Sep 2011
        • 3165
        I usually drill one or two (small 1/8 ) holes in the metal sides on the thermostat. This makes the bleeding process MUCH easier.
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • xxx-Lost-Soul-xxx
          • Apr 2008
          • 1953
          Ever had the climate control on at Full heat and drive around like that for a while?
          • BK544E34
            • May 2012
            • 172
            I will try this... Still is doing the same thing. Having the heater on blast and driving around will still overheat the vehicle.
            1999 M Coupe
            2014 X1 xDrive35i
            2000 P38A HSE
            1989 Lachs 4 Door
            • Aleksey
              • Feb 2011
              • 336
              ? The car is self bleeding.
              OP when you fill up the coolant, start the car and run it then take out the small line that goes to top left side (driver) of radiator until bubble free coolant is flowing.
              • FLG
                • Sep 2011
                • 3165
                The holes help to bleed the car so you aren't waiting for the thermostat to open.
                Sent from my Galaxy Nexus using Tapatalk 2
                • Aleksey
                  • Feb 2011
                  • 336
                  You can use the method I described above, no need to drill anything.
                  • Jean
                    • 18228
                    Yep, these v8 systems are pretty much self bleeding.
