Wondering if this would be as straight forward as the eta to i head swap? Is it as easy as wiring vharness and all i electronics and swapping them all along with ecu? Also would I need a late model trans because the g260 in it now has the 2 reference holes while late models use a cps and dont have those reference plugs?
528e to i head swap
528e to i head swap
Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youTags: None -
It is a simple process, assuming you have all of the "I" parts available. You'll need most of the intake side from an "I" (injectors, FPR, intake, etc..), the harness, and ECU (173 preferred.) I probably omitted something, but this is well documented for the swap. On the timing front, you'll need the toothed harmonic balancer and crank sensor, plus the sensor mount that bolts unto the front.
You will not have to change transmissions, you can leave the sensors in the bell housing (disconnected), or pull them completely. You will need to source a wire set with the #6 sensor attached.
Hope this helps... -
that does help thanks. i was just a little iffy on the tranny part more than anything.It is a simple process, assuming you have all of the "I" parts available. You'll need most of the intake side from an "I" (injectors, FPR, intake, etc..), the harness, and ECU (173 preferred.) I probably omitted something, but this is well documented for the swap. On the timing front, you'll need the toothed harmonic balancer and crank sensor, plus the sensor mount that bolts unto the front.
Hope this helps...
iirc all 528e's were eta bottom ends that will bolt right up to a 885 or 731 head the 88 was just special because of the SETA pistons.Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youComment
isnt the fuse box totally different on a 528e?Yours truly,
Rich
Originally posted by Rigmasteryou kids get off my lawn.....Comment
Ah shit your right. Any ideas on how to make a e30 m20 wiring harness work?Originally posted by blunttechr3v does not fuck around. First you get banned, then they shoot youComment
hi
Configure your BMW vehicle
Are you interested in configuring your ideal BMW? Please select a country to visit the configurator in the Virtual Center or contact your local BMW dealer who will be happy to answer all your questions about the BMW model you are interested in.
signage
Hoarding In U.PComment
