If you've got a 530i/540i manual, could you please take a picture of the clutch line bracket that goes between the hard line from the slave cylinder and the soft line. Long story short, the PO of my 530i removed that bracket (and the 2 hard lines and single soft line) and put in a shadey combo of other lines in a bid to get by without having to replace a broken hard line. I want to go back to the OEM hard lines and single soft line set-up, but I can't figure out where that bracket goes, which is keeping me from getting the hard lines installed. Thanks in advance.
Chris
Here's a RealOEM diagram with the bracket, item #12.
Chris
