Stupid question
    Stupid question
    Do I need to pull off head to fix broken rocker arm?
    1990 535i non vanos Help
    I'm not a 100% on this because I have not done it myself but I beleave you have to remove the head to slide the cam out of the head.
    sigpichttp://www.germanaudiospecialties.com/
    1986 325es :early:
      If you broke a rocker itd be wise to take the head off to examine any other damage that could have occurred.
      Swanny!
      SUCKERS.
        You don't slide the cam out, you slide the rocker shaft out. Cam stays in place.
        Which rocker is it? If it is one of the ones near the firewall, you can probably do it as the shaft only needs to slide out a few inches. If it's toward the front, then it is less likely. You will have to remove the radiator and condenser to make room and at that point, it's almost easier to just pull the head.
          Thanks I knew the answer hoping
            I would pull the head... It's much easier to get the rocker out, plus you can examine for any cracks or anything else. (P.S. There is no such thing as a VANOs M30 :P)
            Originally posted by flyboyx
            how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
            Originally posted by Northern
            beer is my new liver cleanse.
            Henna - '84 Hennarot 325e
            Lola - '89 Schwarz 325is - being saved
            Christine - '88 Schwarz 325is - Spec E30 Racecar
            '01 White F150 Lariat 4x4 Supercrew - Daily
            Dad's '05 Interlagosblau M3
              Stupid Question
              Thanks I am still learning pulling too much on : the motor
