Removing injectors
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    Removing injectors
    How the hell do I remove the fuel injectors? I got the clips off them but the fuel rail is stuck to them aswell as they are stuck into the manifold. I've tried pulling and I'm getting no where is there a trick to it?
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
  • Sean S.
    • Aug 2012
    • 196
    Make sure you have all the 10mm bolts out that hold the rail and injectors to the intake and then just rock it back and forth until the whole assembly pops loose. You can also work one end or the other loose and then work down the line. The entire assembly can be removed quite easily if you remove the valve cover. Inspect the injectors once they are out to make sure the "o" ring and pintle caps are still attached. Otherwise, you have to go fishing in the injector holes for them.
    • ThatOneEuroE30
      • Dec 2013
      • 8626
      Removing injectors
      well the manifold is off the car. taking injectors from a spare manifold to get cleaned that way i dont have to tear it apart and leave it apart
      Edit: got them. Was easy just but manifold on ground foot on manifold and pulled
      • AndrewBird
        The Mad Scientist
        • 11897
        I usually lever them out with a big screwdriver against the valve cover. They are a snug fit.
