Self Leveling Elimination on E34 Touring
  • EyExR
    • Jan 2011
    • 956
    Hi all. I just picked up a self leveling elimination kit from BavAuto and some new rear shocks.
    They advise that you join the lines together that run to the self leveling pump. My question is, could I just install a steering pump from a non-self leveling E34? I have one...
    Anyone ever do this?
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
  • tricars
    • Feb 2015
    • 91
    Yes you can, but if change the pump to a ATF one, you must also swap the steering box to a ATF one, at least I was told the they pair up like that.
    85 coupe 318i(M30 swapped) winter fun machine
    88 sedan 318i Sold :(
    88 touring 324td M62B46 swap in progress
    89 touring 325ix Parted :(
    91 cabrio 320i Sold :(
    92 touring 525tds Parted :(
    • Nick_S
      • Apr 2011
      • 3656
      I made my own SLS delete and it's been perfectly fine for the last 3 years. Once looped you should have a trouble free system, no need to change the pump.
      91 318is M50 swapped
      05 Honda Pilot
      24V swap thread
      • Habla
        • May 2004
        • 1470
        That sucks, I was hoping to do the same.
        -Peter
        318is slicktop | F15 35dM | F250 SD
        • Hool
          • Mar 2016
          • 14
          There are several ways to do a SLS delete.
          On mine i removed the SLS garbage and looped the pumps SLS output back into the reservoir..
          Don't forget to jump the ride height switch located on the rear sway bar to avoid the camber warning..
          I Run normal ATF in mine but if you feel like it you can use the very expensive SLS oil too.. I did not change steering box or anything else.
          • straight6pwr
            • Sep 2004
            • 3450
            baloney. the steering boxes are all the same. they can handle the Pentosin CHF found in SLS and ASC+T cars or the ATF fluids found in the others.
            • bmwstudent
              • Sep 2011
              • 1364
              just flush and fill with all new fluid
              • Brinkley
                • 379
                W/o starting another thread but also sls delete related, I have a 92 touring I've just 5 speed swapped, and an added bonus of the parts car I bought was a bilstein / h&r suspension. Can I just install the rear suspension (along with the ps pump from same parts car) or do I need different springs for my rear end?
                I don't think your mom appreciates the value of those modifications
                • straight6pwr
                  • Sep 2004
                  • 3450
                  should be good with the straight swap.
                  the spring sets have the same rates for tourings/non-tourings it just will sit a little lower in the back due to the extra weight, which is generally a good thing, as sedan e34s tend to sit high in the back even on lowering springs.
                  • Brinkley
                    • 379
                    Thanks! It's got to be better than as is with it completely gone out.
