e34 530i clutch stack height
  • iXguido
    • Nov 2009
    • 730
    I'm trying to put together a clutch setup for my 540 5-speed swap and I need a measurement of the total stack height of the clutch and flywheel on the 530. Hoping someone has one apart at the moment that they can measure for me. Any help would be much appreciated!
    Thanks!
  • JoeP
    • Mar 2005
    • 150
    TTV in England use to sell a single mass flywheel for the M60 that would allow the use of a S52 clutch. Might be a good alternative to piecing a setup together. I was going to go buy one, but ended up selling the car instead.
    I use to have a spare clutch and flywheel in my garage, but I'll have to look to see if I still have it. I'll check tonight and take some measurements if I still have it.
    *Sorry, I checked and no longer have the clutch and flywheel.
    • straight6pwr
      • Sep 2004
      • 3450
      if you are trying to cobble together something, its been figured out already.
      see post #15 in this thread:
      this biggest obstacle is that the 530i 5-speed has a smaller input shaft size, so you can't use any of the larger 540i clutch stuff.
      if you know all this, and are getting the info for other reasons, maybe the above thread can give you different options for what other parts can be measured to give you the same stack height. not too many 530i/5 guys around.
