E34 Touring Hatch Glass Stuck
  • noypi2
    • Jun 2014
    • 442
    Any tip on opening my Hatch Glass without breaking anything to access the wires.
    Sent from my SM-G930T using Tapatalk
  • FireFight
    • Mar 2012
    • 1367
    Will the whole hatch open?
    WTB:m60b40 in PNW
    Zachary Ripley
    85 318i M50B25tu.
    92 525it 5 speed.
    80 244gl (m60 prepping).
    • noypi2
      • Jun 2014
      • 442
      Yes..the whole tailgate/Hatch open.
      • BlackSpeed66
        • Apr 2008
        • 624
        Which wires are you trying to access?
        -Geno
        '87 325is (s52'd)
        '95 525iT
        '95 Jaguar XJR-6
        '02 Range Rover 4.6 HSE
        '98 Disco 1
        • AndrewBird
          The Mad Scientist
          • 11898
          You can manually pop the glass from the backside after you take the panel off. Find the rod connected to the actuator for it and pull or push until it pops.
          The damaged wiring will likely be under the hatch though, not under the glass. It always break where the hinge for the hatch is where it has to fold 180º on it self.
          • noypi2
            • Jun 2014
            • 442
            The wire under the black trim on the driver side tailgate. The screws are located under the glass hatch.
            • noypi2
              • Jun 2014
              • 442
              I will try to do that. Thanks.
