Rough Idling/running & CEL after performance chip install (M42)
  • BoxE30
    • Aug 2020
    • 72
    Hi guys,
    Long time lingerer/searcher on the forum. I had an issue arise for which there seems to be smaller/more specific potential fixes, but figured I'd put this one out there. Quick history: I purchased the car late last year with a rough idle and a bad profile gasket, having the job done by a good local shop here in San Diego not long after purchase. Since that job, the car has run fine, with just the slightest hesitation at startup, but give it some gas for a minute or two and it's fine.
    Yesterday, I installed a Turner Conforti performance chip and it immediately had very rough/shaking startup, with rich exhaust fumes, that seemed to get better when I kept giving it gas for a decent while. Once it leveled out and idled fine, I took it for a spin - nothing aggressive - just running it on streets with a small freeway distance. Came back, turned it off, and started it again. Seemed to start and idle alright when hot.
    I went ahead and put the stock chip back in just to see if the new chip was the problem. Started it when it cooled down for a while and seemed to have the same issue even with the stock chip this time around. I then went ahead and cleaned out the ICV, which was dirty, but wouldn't say filthy, and still has the same issue.
    Today, I put the Turner chip back in and it had the roughest start so far, even squealing the belts a bit. Kept on the gas for a decent while and it then threw a CEL and wouldn't even idle properly when heated up. Pretty concerned at this point that I may have damaged something. Any ideas?
    Thank you in advance!
    Sean
  • prisonerofdoom83
    • May 2013
    • 527
    Stomp test for the CEL?
    • twright
      • 707
      My M42 acted like that when it wanted new ignition wires. Unfortunately, they are hard to test and expensive. I'd try everything else first.
      • turner.e30
        • Aug 2020
        • 42
        I'm assuming you disconnected the battery before you installed the chips? The DME will "reset" when the battery is disconnected and will need some time to sort itself out. Does it clear up once you drive it for a bit?
        • BoxE30
          • Aug 2020
          • 72
          Yes, battery disconnected. How long for it to reset itself?
          • BoxE30
            • Aug 2020
            • 72
            Tried one yesterday but didn't get any feedback from the dash. I then found out this afternoon I needed to close the door (open since it was very hot yesterday). I'll give it another try tomorrow.
            • turner.e30
              • Aug 2020
              • 42
              Shouldn’t be very long. A few times around the block should do it. If it doesn’t clear up pretty quickly then there might be an issue of a different kind.
              • Codym42
                • Mar 2013
                • 611
                Make sure to check this... https://www.r3vlimited.com/board/for...-this-wire-for
                '90 325i - 5 speed coupe
                '05 330ci 6MT ZHP
                • BoxE30
                  • Aug 2020
                  • 72
                  Originally posted by Codym42
                  Glad you brought up. I checked and thankfully not connected. As for the CEL, I put a new (to me) DME in that hadn't been tampered with and the car runs fine again. Thinking I must've had static that I hadn't grounded properly when I got into the first DME. Getting a replacement Turner chip and seeing if it changes anything on either the first DME or the 2nd one.
