e30 drivers door dome light problem
  • abazbazat
    • Jan 2022
    • 3
    Hi hoping everybody is having a great start of the year, I have been working on my interior lights today and the driver side does not work with the door open , only on the always on position, I tried cleaning all the contacts adjusting the pin switch, I am going crazy . One thing I noticed is the dirver side pin switch has to pole and one is disconected. Is there something else I should check or could do? thanks to all
  • Northern
    I like cupcakes & sh!tboxes
    • 5284
    This won't be much help, but I have similar issues, and trying to adjust the switch hasn't helped me either.
    If I wiggle the switch with my finger I can get the light to turn on, just never by the action of opening the door.
    61311370805 is the PN for the driver double pin switch, they're currently like ~$28-33 USD so I caved and bought one.
    Originally posted by priapism
    Originally posted by shameson
    • abazbazat
      • Jan 2022
      • 3
      Hi did the new switch solved the problem?, I tried to earth the cable directly and the light did turn on, on the double pin switch you have two connections, one with a green/purple cable and the other is disconected, do you have both terminals connected? may that be the issue?
