Garagistic Supreme shifter issue
  • Papasta318is
    • Apr 2022
    • 9
    Hey Guys,
    I’ve got an issue with my Garagistic supreme shifter and I am hoping to see if anyone else else has encountered this issue.
    running all new bushings, new bitch clip, new Garagistic selector joint, dssr (homemade).
    I’ve checked and everything is tight. But if everything were tight I’d imagine it would be a vibration, due to being a solid assembly, not a rattle like it is.
    I’ve also pulled the shifter out and tightened/used lock tight on the shifter and the bug nuts, to ensure they aren’t rattling.
    thanks,
    Nick.
    video, sharing, camera phone, video phone, free, upload
  • It's Soda Not Pop
    • Jan 2022
    • 875
    Is this a chassis mounted shifter? And if it is and you have solid trans mounts, then there will be some rattling and/or vibrations. Getrag's rattle.
    88' Seta 2.7i Zinno
    https://www.r3vlimited.com/board/for...430-my-88-seta
    • It's Soda Not Pop
      • Jan 2022
      • 875
      I have their chassis mounted shifter and DSSR with solid trans and engine mounts. It vibrates. But it doesn't bother me I knew this was going to happen
      88' Seta 2.7i Zinno
      • Papasta318is
        • Apr 2022
        • 9
        Thanks for the reply! Not chassis mounted, just they’re short “supreme shifter”, and I’m running oem bushings, replaced just last week.
        • It's Soda Not Pop
          • Jan 2022
          • 875
          Click image for larger version  Name:	bmw-e30-poly-rear-shifter-carrier-bracket-assembly-K0022_61292ed7-e088-4571-9a05-bf98e05c63f9_900x.jpg Views:	0 Size:	74.9 KB ID:	10054743
          Did you change out the carrier mount to a more firm/solid bushing?
          88' Seta 2.7i Zinno
          • It's Soda Not Pop
            • Jan 2022
            • 875
            After watching your video I'm not sure what causing your rattling. My car vibrates but it doesn't rattle the shifter. I mean my tranny rattles in neutral but that's common. Maybe your carrier bushing is shot if you didn't change it. Or if you did change it to a firmer one it could cause some NVH issues. Are the engine mounts new as well?
            88' Seta 2.7i Zinno
            • Shangsta
              • 1485
              Did you ever get this figured out. I also am in the same position and it’s really annoying
              :shock:
              • It's Soda Not Pop
                • Jan 2022
                • 875
                What bushing and/or mounts have you changed? If everything but the shifter is old, then you should probably look into a refresh. All of my stuff is hard mounted. All delrin or solid. I have NVH but no rattling. Getrag's kind of rattle anyway (they are known for it). I recently replaced my clutch and flywheel along with going standalone (I raised my idle to 900). My transmission no longer rattles as harsh as it used to after doing the things I just mentioned.
                88' Seta 2.7i Zinno
