Late model bmw e30 rear height adjusters !! Need help !!
  • DAN-E30
    • Apr 2022
    • 28
    So i installed 6'' in length 2,5'' DIA rear springs (GC150.64.92 - 6/2.5"/525 LBS) on my late model e30 coupe and it slammed the rear dramatically on my 17s inch bbs wheels, it's not even 5'' in length springs, so go figure.
    Anyway. im on the hunt now for some rear height adjusters to raise the rear such as Vorshlag rear adjusters whithout breaking the bank. i would appreciate it if you can guide me in the right direction to find out some models to order on a budget please.
    It's seems that most of the rear adjusters avaible online are for 2.25'' DIA. or 60mm DIA. springs. I can't figure out a model for a 2.5'' DIA. spring which is around 63mm DIA. (Except the 290$ Vorshlag adjusters that seems to work with a 2.5'' DIA.)
    Thanks in advance guys, i appreciated
    ps: in case someone is wondering, i will be replacing my rear bilstein shocks with the yellow short Konis.
  • TobyB
    • 5296
    2.5" threaded sleeves are really common- ePay sells them to the Honda Tuners by the containerload.
    https://www.speedwaymotors.com/Coilo...eeve,2184.html
    I have just been using spacers under the bottom side of the spring- some chunks of 1/4" aluminum with holes
    for the nipples, and vwallaah- a 3/8" height adjustment.
    t
