How to fix this dash went crazy?
  • Tofflemire
    • Sep 2022
    • 17
    A couple days ago I forgot my E30’s lights on while at the office.
    When I got back the car wouldn’t start. After resting for 10 mins it finally went on but this happened.. any advice on how to fix it? I love this darn little display
    Inviato dal mio iPhone utilizzando Tapatalk
  • Vincenze
    • Apr 2019
    • 1042
    You can disconnect and reconnect the battery.
    Or you can use nails to remove the clock front panel, then you can press on the tabs and move the clock out. Then, you can disconnect the clock connector.
    • roguetoaster
      Biggus Tippus
      • 7830
      The six button displays suffer from some type of connection issue, either on a circuit board/ribbon cable, or on the wiring connector at the rear. Normally a little tap on the face of the OBC fixes it for quite some time.
      • jbontke
        • Mar 2019
        • 449
        I am in the same boat. I press a button until it stops. No other real fix, mine tends to act up as the weather changes???
        • dhlerner
          • Jun 2018
          • 14
          +1 a tap to the faceplate or a button push usually fixes it. Sometimes I just let it go and it's more entertaining vs. the boring clock view.
