Need help with question
  • Nate.E30
    • Nov 2022
    • 10
    Asking question, need help.
    so I was looking at my oil cap and I found this I have no clue what it could mean and it does seem normal.
  • mjweimer
    • Dec 2015
    • 648
    I'd say it looks normal; no milky film from condensation or thick chocolate milkshake mess from a headgasket issue. Does it have any hint of a fuel smell? What is your specific concern?
    • TobyB
      • 5268
      On my monitor, it looks like green coolant.
      But that's just an observation.
      To help you with your question, you should make the subject "substance on oil filler cap?"
      or something along those lines.
      t
      • Nate.E30
        • Nov 2022
        • 10
        Yeah it smell a little like fuel but not to much. And my coolant is blue. Also thanks for the help with that I’m new to this stuff
        • mjweimer
          • Dec 2015
          • 648
          We were all new at this at some point so don't sweat it. A bit of fuel smell is probably just the normal smell used oil gets after some time in the engine. As to the color, I do see a slight hue, however the lighting might be exaggerating the normal color of the oil.
          If you want solid peace of mind, go to https://www.blackstone-labs.com and order up an oil sample kit and at your next oil change take a sample and send it in for analysis. No better way to judge the health of the engine without opening it up.
          • lukeADE335i
            • Apr 2013
            • 1386
            Is the car new to you? If you’re not sure what oil is in it, the greenish tinge (if that’s not just the photo) could be liquimoly molygen oil that has dye in it to make it easier to spot leaks? Not sure if other oil manufacturers have taken on that idea as I run nothing that exotic in the e30. I just get Penrite synthetic when it’s on special, which is just the normal brown colour like Dino oil.
            My e30: OEM+ with M30B35
            • Nate.E30
              • Nov 2022
              • 10
              Alright yeah thank you guys I’ll check out that oil kit and I definitely don’t think there is anything special like that in it.
