injectors
  • 416stroker
    • May 2008
    • 2448
    injectors
    I have some new ones bosch pn:0280 150 778 I dont know the flow rate on them dose anyone know ? all the charts online are diff. they are stock for a 94 740?
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • xLibelle
    • Aug 2004
    • 2673
    191 cc/min
    • Fidhle007
      I can fly, motherfucker
      • Oct 2005
      • 7209
      About 19lbs/hr so the should work with a MarkD chip or something like that.
      '89 325is S50 Track Montser
      '04 X5 Daily/Tow Vehicle
      http://www.avarestoration.com
      http://www.myspace.com/brendanfiddle
      Click here if you want to be my zombie slave...
      http://www.youtube.com/user/Fidhle007
      • 416stroker
        • May 2008
        • 2448
        Ok cool thanks Ill have to get a chip for it then I just want to replace my 17lb on the m50
        84 318I Delphin RIP
        89 325 Alpineweiss
        • xLibelle
          • Aug 2004
          • 2673
          hmm, the conversion is divide cc/min by 10.5 to get lb/hr
          which means the injectors are 18.19 lb/hr
          • 416stroker
            • May 2008
            • 2448
            So im not going to need anything to run them there not much bigger IDC if I run a lill rich
            84 318I Delphin RIP
            89 325 Alpineweiss
            • Fidhle007
              • Oct 2005
              • 7209
              You should chip/tune it ideally.
              • 416stroker
                • May 2008
                • 2448
                It will happen some day. Im just out of workright now so im limited to what I can do.
                84 318I Delphin RIP
                89 325 Alpineweiss
                  • 34844
                  if your O2 sensor is working it will be fine, not neccesarily tuned perfectly for every part of the map, but the computer can easily compensate.
                  • einstein57
                    • Jun 2007
                    • 10780
                    Mine runs great with mustang injectors and 037 afm.
                    www.gecoils.com
