Is it possible to lower the E30's steering wheel position? I know a bunch of old cars have the steering column adjustment but is it possible in the E30. I'd like to drop the wheel about an inch or two. Any idea's?
Steering column adjustment?
Tags: None
I've seen someone put a spacer in there. I'll try and find the link for you.
So, yes, it can be lowered a little.turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together. -
Found it.
If you haven't seen the whole thread, go ahead and do so now. Mint build up there.
The post about the steering column drop is #245turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together.Comment
Ran into a delema...
Bmw uses round bolts to lock in the steering column how the hell do I remove them...
Something like this but the other side where the bolt gets locked in round also! How the hell...
RComment
they are shear bolts, they are meant to break in the event of an accident. I'm not sure I would mess with them just to lower the column, personally.Comment
yes and no. they are shear bolts, but it is for anti-theft, not accident collapsing. when they install the bolts at the factory the head breaks off to prevent somebody from unbolting the column and bolting another in to drive the car off without the original key.
to remove them, I made a big slot in the heads like a screwdriver slot with a dremel tool. Then i took a punch and hammer and banged on the sides of the slot to start the rotation. Once broken loose just stick a screw driver in there and unscrew them.
I put a 50mm spacer in mine to bring my colum down. works great!Comment
Just blasted them out with a drill. Came out nice an smooth going to go pick up new bolts an bushings. I'll snip some pix for who ever is thinking about this.RComment
interesting, good to know. I do know the airbag column is a huge pain in the ass.. the non-airbags don't have those bolts AFAIK.yes and no. they are shear bolts, but it is for anti-theft, not accident collapsing. when they install the bolts at the factory the head breaks off to prevent somebody from unbolting the column and bolting another in to drive the car off without the original key.
turk@gutenparts.com
