Hood latch lever Help Please
  • TooTall90
    • 338
    i need help fixing my hood latch lever ( im not sure the real name but the lever you pull to pop the hood). the lever was never in perfect working order since i've had the car, but it would still work, you just had to shimmy it back and forth a couple times. im not sure who broke it or how ( not me for sure prollly my dad) but i think whoever did it just ripped it back and, well now, its broken. anyone ever have this problem? my guess would be a loose/broken cable or the actual lever (2 pieces) are broken. i did go down and try to fix it but after an hour or so i decided to see what R3V has to say. i might just have to go buy a new one at the dealership, not many e30s in the yards around here. HELP PLEASE i cant get my hood open now, which i will probably need to do sometime in the future :(...
    Strategic Alpine Command:...sig loading
  • scott_is
    • Aug 2007
    • 310
    Buy a new cable/handle assembly 45$ Can from the dealer... I just did
    this 2 days ago very easy. make sure you clean the lock that hold the
    hood down.
    To open your hood look behind your driver side grill right next to the high beam you should see two bolts and a hole with a slot in the middle stick a long flat screwdriver in the slot and turn right your hood should pop up.
    hope this helps
    Scott
    • TDE30
      • 7042
      Better yet, buy my $5 one. It works fine and I can ship it out Priority Mail tomorrow AM.
      Let me know, best of luck.
      - Trey
      E90 325i/6 (ZSP, ZPP, ZCW)
      E36 325i sedan
      E30 325i sedan
      Volvo 945T
      • TooTall90
        • 338
        thank you guys for the help. i will try to get this done asap. TDE30 do you have the cable to attach it to the lever? i think i might need the lever handle as well as the cable.
        • iwillhunt
          • Oct 2007
          • 385
          I just keep a flat-head screwdriver in my car.
          • TDE30
            • 7042
            Sorry, the cable isn't included with the handle. I know of the cable to which you are referring though, is it severed? That may make the task a bit more difficult.
            - Trey
            E36 325i sedan
            E30 325i sedan
            Volvo 945T
            • TooTall90
              • 338
              well scottis who says hes recently done this says he had to open the hood, so im guessing i will need the cable. no mine is not severed atleast not from what i can tell, but i would like to have all my bases covered. 5 dollars is an excellent price, i will try to find more answers to be sure, thanks. anyone else ever deal with this problem???
              • homegrone30
                • Jun 2007
                • 1449
                I just keep a bag of screwdrivers in my car.
                • TDE30
                  • 7042
                  Someone else PM'd me about it and asked for my PayPal info, I'll let you know if he decides to buy it. If he does, you can find these things all day long at any Pull-A-Part/Pick-A-Part, two screws, done.
                  - Trey
                  E36 325i sedan
                  E30 325i sedan
                  Volvo 945T
                  • Liam
                    • 753
                    You should snap a picture of the location of the release hole behind the grill and do a write up on how it's done before someone tries to pry their hood open.
                    I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃xS : φ(x)) → (∀xS : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
                    • iwillhunt
                      • Oct 2007
                      • 385
                      Get a long flat-head screwdriver.
                      Look to the left (when facing the front of the car) of the driver's side high beam, through the grill, 2 or 3 slats from the top.
                      You will see a circular hole with two pieces of metal coming together in the center of the circle.
                      Insert flat-head screwdriver between these two pieces of metal, and twist handle.
                      The hood will pop open.
                      • SkinnyVT
                        • Nov 2008
                        • 391
                        '86.5 325eis Track Ho | '08 128i DD | '04 Silverado Tow Vehicle
                        • txtorquemade
                          • 1758
                          Wow..this is great. Bumping a thread thats a lifesaver. The dumb ass auto tech school thats had my car for 8 months ( and did nothing) broke the damn hood latch.
                          sigpic 1987 325is
