Alignment need help 1988 325i
  • chrisvalentino1
    • Aug 2022
    • 8
    Good morning I need help so yesterday I took my E30 to the my brother shop to get my car on alignment. We got on the machine then we started to do the rear first, as we started doing the the cambered the numbers on the computer never changed and when we did the tow the number never changed as well. So I need yall help to definitely this problem so I can get this fix so my tires won’t get chewed up 😭💯
    • 37829
    The rear of an E30 has no camber or toe adjustment unless aftermarket parts have been installed.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • uturn
      • Dec 2010
      • 1001
      Just went through the same ordeal with the black e30. Replaced rear subframe bushings and trailing arm bushings. Passenger wheel still had excessive camber. Had to replace the complete trailing arm to correct it.
      Your bushings may be worn or trailing arms might be bent from a past accident.
