Engine bay dimensions
  • Gaslover
    • Apr 2024
    • 3
    I am currently on the look for an e30 to start my project car life. In doing so for this process I would like to do an engine swap and I’m looking for the dimensions of the engine bay to know what engines I can officially fit in there or for other engines I would need to mod the car for proper fitting. I’m looking for the subframe to the hood, or just the overall length, width and height.
  • 82eye
    • Jan 2009
    • 2108
    near every swap that fits is already documented. quickest way there is see what worked for others. otherwise there is a thread with a 3d scan of the car here somewhere including the bay. do a search for the thread and have a look.
    edit : E30- S65 Swap and 3D Scanning - R3VLimited Forums​
    • Gaslover
      • Apr 2024
      • 3
      82eye thanks for the advice, and the link. I didn’t find much info for dimensions from anything but I did research on engines and most of the bmw m series fit if I’m correct and same for the s series. Still haven’t found any dimensions however even after searching for a while. :(
      • 82eye
        • Jan 2009
        • 2108
        there is a v8 swap sub forum. if you go through similar builds you'll dig up what you are looking for. V8 Swap - R3VLimited Forums​
        • bangn
          • Sep 2011
          • 760
          You'll fit pretty much everything in there , the issue is that shitheap booster location that ruins most conversions.
          Boris - 89 E30 325i
          84- E30 323i
          • 82eye
            • Jan 2009
            • 2108
            this.
