Misfire that sometimes goes away under load
  • E30CSWolf
    • Aug 2024
    • 2
    Hello all. I have a 1990 325i that’s missing at idle and sometime under load. But not always. I replaced the plugs, wires, distributor, rotor, coil, injectors, fpr, vacuum lines, and fuel filter. I’m not sure what’s next to check. Any advice and help would be appreciated
  • 82eye
    • Jan 2009
    • 2108
    start with these diagnostics : Diagnostics, tips, & tricks by Jim Levie (E30 Jedi Master) - R3VLimited Forums
    the issue will be in there. ​
    • E30CSWolf
      • Aug 2024
      • 2
      Much thanks friend
      • MrBurgundy
        R3V Degenerate
        • Mar 2012
        • 5609
        Check the connector under the intake. It's for the fuel injector harness and coolant temp sensors.. Sometimes you'll find some corrosion or loose pins..
