Any one ever had a seat break?
  • 416stroker
    • May 2008
    • 2448
    I was getting on the freeway the other day and when I grabed third gear coming out of the little S turn on the on ramp the frame on the seat back snapped in half on one side. Wierd? Its not like a fat ass or anthing I only weigh 180
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • E30SPDFRK
    • 5716
    Happened to my friend in my passenger seat about a year ago. Taking a rotary quickly and it popped up on one side then fell down. Still haven't gotten around to fixing it, lol.
    Byron
    Leichtbau
    • 416stroker
      • May 2008
      • 2448
      Ya its wierd it happend dead even with my left shoulder. It could be welded but i have my eyes on some recaros.
      Where did it break?
      84 318I Delphin RIP
      89 325 Alpineweiss
      • Liam
        • 753
        Not myself, but I sure have fixed a lot of them over the years.
        I'm Not Right in the Head | Random Rants and other Nonsense1st Order Logic Failure: Association fallacy, this type of fallacy can be expressed as (∃x ∈ S : φ(x)) → (∀x ∈ S : φ(x)), meaning "if there exists any x in the set S so that a property φ is true for x, then for all x in S the property φ must be true".
        • Danny
          • 14216
          nope u r fat.
          • mach schnell
            • Apr 2008
            • 1059
            How do you fix them? Where do they break?
            • Liam
              • 753
              Usually the upper frame just breaks at the pivot or the pivot breaks off the lower, if it's not too busted up I have pulled off all the upholstery and TIG them or if they are shattered to shit, just replace the frame.
              Granted I'm not doing this on a whole lot of e30s anymore. But I'm pretty sure the seat frames are still available.
              Doing a lot of e36 and 46s now, some things just don't change much.
              EDIT: Oh Sometimes the back just comes loose, 2 screws hold the brackets in place and the gremlins loosen them up every 10 years or so.
              • 416stroker
                • May 2008
                • 2448
                anyone local have some sport seats grey or black no tan?
                84 318I Delphin RIP
                89 325 Alpineweiss
                • bejbis
                  • Dec 2008
                  • 596
                  yeh, if it lifts up on one side and not the other, the screw came out, pull off the rear cover, there are two small phillips holding it on at the bottom of the back of the seat. then you will see two bars that hold the seat back to the seat bottom, there is one large phillips screw on each, one of those fell out. whole process to fix it should take no more than 5 min per seat.
                  -Dan
                  • 416stroker
                    • May 2008
                    • 2448
                    Yea thats an easy fix. but not what happend to me.
                    84 318I Delphin RIP
                    89 325 Alpineweiss
                    • ethree
                      • Aug 2007
                      • 1216
                      Here's a local set. No affiliation, not mine etc.
                      • Charlie
                        kid tested, administrator approved
                        • 6686
                        They all break eventually. Anyone's that hasn't by now, is close.
                        -Charlie
                        Swing wild, brake later, don't apologize.
                        '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                        FYYFF
                        • //MPower
                          • Jun 2007
                          • 182
                          Both mine have broken before.
                          Turns out it was just a bolt that holds the back of the seat on had came out. It was an easy fix both times.
                          | Jimmy | 1999 M3 | 1986 325 ES |
                          • Hallen
                            • 1008
                            Anybody ever have the lower frame break? I have one seat that on the outside is in very good condition, but the lower main frame rail is broken. It works, but it is a bit crooked.
                            It thought it was odd that the lower frame had broken like that.
                            1987 E30 325is
                            1999 E46 323i
                            RIP 1994 E32 740iL
                            oo=[][]=oo
                            • elsabor67
                              • Jan 2008
                              • 837
                              Yeah, mine broke on both sides. Not hard to replace but a pain in the rear to take the cushion and upholstery off. I noticed it when I was leaning too much to the left and couldn't adjust.
                              How do I spell stress relief?:hitler:
                              :!:Open Track Days!!!:!:
