Alternator Pivot Bolt
  • ale909
    • Apr 2009
    • 2
    I have been lurking here for a while as I undergo a piecewise restoration of my new, to me, 1989 325i. This website has been invaluable and for that I thank you all very much.
    I was swapping my old alternator, original w/ 225,000+, today and I either lost the nut that was on the back of the pivot bolt or it was never there (couldn't find on the ground or in any underbody trays). I am kind of confused because if there was a nut, then it was being held captive by the alternator bracket which holds it to the engine. I never could have got a wrench on the nut it in the first place. Ultimately, I only needed to use my 13mm ratchet on the pivot bolt head to remove it.
    Was there a nut on the back of the alternator pivot bolt?
    Thanks in advance for your help.
    Aaron
  • twright
    • 707
    Yes.
    Its trapped in there by the casting around it. (You don't need to put a wrench on it to keep it from spinning.)
    • ale909
      • Apr 2009
      • 2
      Thanks for the reality check. Off to the dealer to buy a new one, just could not find it on the ground.
