control arm broke and oil pan destroyed
  • Goya20
    • 325
    I was driving my e30 when my driver side control arm broke in half and i was in the middle of turning i lost control and the car went into the curb breaking my oil pan. do you think if i fix it up will it start cuz the oil pump within the pan looked like it was hit also. so im getting a new pan and control arm and buy some oil. thanks leave me with some advice
  • Wiglaf
    • Jan 2007
    • 1513
    when you get the old pan off, the oil pump is easy to pop out to inspect.
    Originally posted by u3b3rg33k
    If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
    • 884door
      • Nov 2008
      • 380
      I recommend replacing the pump as well, as long as you didn't leave the engine running after the oil all leaked out it'll be fine.
      On another note i have an oil pan i'm trying to sell for $125 and if you're interested i'll throw in an oil pump for free because of your shitty situation.
      • Lurker27
        • 821
        As per the bentley, you can turn the oil pump sprocket by hand with the pickup submerged to test it. I would replace it regardless, the guy above me is giving you a very good deal.
        '89 335is +turbo
        • guibo09
          • Dec 2008
          • 834
          wow thats a pretty nasty catastrophic failure!
          can you post a picture of the broken control arm? a zoom up of the fracture surface would really be nice. metal failure is my job, i can give some insight on the cause.
          90 E30 325i
          • catchuk
            • Jan 2008
            • 344
            Was it an aftermarket control arm?
            • Wiglaf
              • Jan 2007
              • 1513
              I'm curious as well, particularly if there's something I could look for to avoid this situation.
              This def could have been a lot worse than just an oilpan.
              • dannyyisntt
                • 3141
                just as a precaution i'd prolly replace the other control arm too
                  • 37833
                  Control arms don't just break in half all on their own! I have seen them severely bent and still not broken!
                  Grover Beach, California
                  BimmerHeads.com
                  • Dave
                    E30 RAT
                    • 11675
                    i think the curb helped it . . .
                    Current Cars
                    2014 M235i
                    2009 R56 Cooper S
                    1998 M3
                    1997 M3
                    • CorvallisBMW
                      Long Schlong Longhammer
                      • 13039
                      Yikes, that sounds like a nasty accident. Good luck getting it all fixed!
                      • Lance Racing
                        • Jul 2005
                        • 2340
                        Thus the reason every PPI and track tech inspection includes inspecting the control arms.
                        Lance Richert '88 M3, #35 PRO3, i3 etc.
                        www.LanceRichertArchitect.com
                        2019 E30 Picnic Weekend: June 22-23 2019
                        • ejnight
                          • Apr 2007
                          • 3488
                          You are luck it was not worse. Glad to here you are OK. Definitely replace the pump when you are in there. and Skid Plates Rock.
                          http://raceskids.com/
                          • etxxz
                            • Feb 2006
                            • 2085
                            dayuum. i believe the ball joint popping out and causing that... i saw it happen at an auto-x once, but broke in half from driving normally....idk. you need to inspect the pump when you take off the the damaged oil pan. i'd rather replace that $130 part now than later and have to drop the oil pan again.
                            No more e30s for me.
                            88 black BMW OBDII 332is dedicated track [sold]
                            88 BMW OBDII bronzit 332is [RIP 03/08]
                            91 BMW 325i [sold]
                            86 Corolla 'Ae86' HB 20v trd [sold]
                            http://youtube.com/watch?v=pTj7Hn9v5Rs
                            • xLibelle
                              • Aug 2004
                              • 2673
                              pictures of said control arm
