Interior lights flicker when I turn brightness knob up…
  • mjr24
    • Jul 2025
    • 10
    It doesn’t do it unless I’m actually turning the brightness knob up. They just flicker for a second but otherwise they are fine.
    Is this normal?
  • MrBurgundy
    R3V Degenerate
    • Mar 2012
    • 5591
    sounds like a dead spot on the dimmer
    • 82eye
      • Jan 2009
      • 2087
      contact cleaner might help. the used for computers, electronics, etc.
      • mjr24
        • Jul 2025
        • 10
        So you mean take the switch out that has the dimmer knob and clean that, correct?
        • mjr24
          • Jul 2025
          • 10
          You mean on the dimmer switch in the dash, correct? Or is there a separate relay somewhere?
          • 82eye
            • Jan 2009
            • 2087
            you can do that or spray it in place. used to buy and sell 80s/90s stereo equipment, it worked really well on dirty potentiometers etc. i've used it to clean a few car switches over the years as well.
            • mjr24
              • Jul 2025
              • 10
              Thanks, will try that tomorrow. I can already tell my new best friend with this car is going to be contact cleaner. Those switches are expensive as hell now….$250.
              I hate going to realoem to see how cheap a part is supposed to
              be (I don’t know when their pricing is from?) just to do a google search and see it’s going now for 3-4 times that.
              • mjr24
                • Jul 2025
                • 10
                So I did this just now and I feel it’s fixed the issue. I won’t know for sure until it’s dark out.
                On another note, could this have had some effect on my service indicator lights? When I got the car a few days ago….the second to left green light was not on but the other four were (see picture). I don’t think that’s how it works normally….so I figured I had a burnt out bulb or a bad solder on that second to left LED.
                However, I noticed today all 5 green ones are lit. Could spraying contact cleaner on that headlight switch have fixed that? I know the dimmer controls the instrument cluster dim, too…..but I don’t think the service indicator lights or the warning lights next to it (brake lining, etc) dim even when you dim the brightness to the lowest setting.
                • mjr24
                  • Jul 2025
                  • 10
                  Edit: now only 4 are lighting up again with that second to left burnt out. Oh well.
                  On the plus side, I do think the contact cleaner fixed the flickering issue with the dimmer switch.
