Who's interested ....Steel Oil Pan M20 E30
  • michaele30
    • 2
    OK
    First off let me start by saying, I have personally replaced my oil pan 4x having owned and driven an e30 on and off for 10yrs.
    IF YOU DRIVE A LOWERED E30 THEN PLS CONTINUE READING!!!
    I finally came up up with this idea to have a repoduction pan made out of punched out/pressed steel, similar to many other pans found on late model cars of today and yesterday.
    Benefits: Can take a lot more abuse, can be dented and will not CRACK/Shatter like OEM. Dents can then be hammered back out depending on severity. Other than that, it will perform all the same duties as the OEM Cast Aluninum part, and hopefully be cheaper.
    Here is what I am proposing. I have been in communication with several manufacturers of steel pans. I propOsed this idea to them and several have expressed interest in working with me to produce this REPLICA part in steel, rather than Cast Aluminum.
    I don't have pricing info yet. I need to get a feel as to how many I need to request, as they price based on volume.
    Please post a reply to express your interest or comments.
    PS- If I am not mistaken, one of the 525i (e34) models used a pan like this, but for some reason not on the e30.
    More info to follow..please spread the word, the mroe the better the pricing!!!
  • rThor432
    • Feb 2007
    • 3907
    Looks like it. I know the E28's did as well, but I think the shape is different.
    There are a few guys making skid plates for these though, and it's a good bit easier to install those than an oil pan.
    • Naplm00
      • Nov 2008
      • 1573
      why not just use a bash plate?
      I have ej knights
      the fisr day i wne t out with my lowered car, it saved it
      88 325ic ~~~> Rusty and ugly
      85 E ~~~> RIP
        • 34839
        maybe if you added some oil control baffling inside, it might be worth something.
        IMO, steel oil pans are a pain. They tend to warp around the bolt mounting points causing leaks.. plus if it was so much better, why do almost all cars have aluminum pans?
        • Naplm00
          • Nov 2008
          • 1573
          just to play devils advocate here:
          because most cars are designed with enough suspention travel / engine mounting to avoid a catastrophic impact?
          85 E ~~~> RIP
          • NC325iC
            • Mar 2004
            • 6565
            not that most people would ever need one, but no one to my knowledge offers an off the shelf dry sump pan for an m20. and i include myself in that most people
            • ieatpeople
              • Mar 2008
              • 883
              i was under my e28 528e on saturday, and noticed the steel oil pan for the first time. i was wondering why they didn't use it on the e30's?? i have heard about all the poeple that crack the aluminium pans on stuff, and thought "why not just run a steel pan?"
              Originally posted by BillBrasky
              That's like Vlad challenging Chip Foose to a car painting contest.
              Originally posted by acolella76
              i'm pretty sure 'Phillis' is short for syphilis
              2007 CVPI, stock and slow
              1994 tercel, 5efhe swap, i/h/e
              1984 t-type, 5.3/th350 swap in progress
              My newest addition:
              Rebecca Arlene, born 4/19/2013
              • allwheeldrive
                • Jan 2008
                • 272
                I have to disagree here. The only reason a steel pan would warp would be from installer error. Typically, silicone would be used for the gasket instead of a rubber or cork gasket. If the silicone is applied properly and allowed to cure, bolts tightened properly, then it'll last 100k miles easy without leaks. I've seen it and done it day in, day out with Toyota's and Subaru's alone. All of whom use steel pans. That being said, would you be able to use silicone for the gasket instead of the crappy pre-made gaskets that'll wear out in short time?
                • JasonC
                  Site Manager
                  • 14451
                  I'd have to agree with this.
                  1992 BMW 325iC
                  1978 Chevrolet Monte Carlo
                  • dashboardmonkey
                    FUCK YOUR WAFFLES
                    • Jun 2008
                    • 6158
                    With a steel pan you could make it hold more oil, thus maybe resolving the oil starvation issue on long hard left turns.
                    -Andy
                    • Hallen
                      • 1008
                      I would agree with this too. Especially for those of us running without the A/C components, it would be easy to extend the pan out the right side just like it is on the left. Put some baffles in and all would be good.
                      Of course a good quality windage tray would be welcome too.
                      1987 E30 325is
                      1999 E46 323i
                      RIP 1994 E32 740iL
                      oo=[][]=oo
                      • Knockenwelle
                        • Jul 2008
                        • 395
                        IMHO, oil pans are only a problem on lowered cars without enough springrate or proper bumpstops.
                        Then there's the odd rock or big pothole in the middle of the road, but unless said obstacle entirely unavoidable, it shouldn't be a problem.
                        Though not a concern on the M20, replacing the factory aluminum pan will reduce overall case rigidity slightly. The clamshell might not fit. Dents that can be repaired may still break the pump or pickup. Factory baffling in the pan is pretty good.
                        Other than those concerns, a steel pan is perfectly viable. Have fun.
                        Mike
                        '91 325i track car. Mostly...
                        • SpecM
                          • Oct 2005
                          • 4531
                          +1 to more oil capasity
                          1989 cirrisblau-metallic 325i
