im thinkin about getting the 91 octane chip. is a bigger fuel pump needed for the stock injectors? i do believe there 14lb... correct me if thats not stock. thanks
mark d chip? injectors needed
dont need a maf(first time im hearing the m3 as an option, usually you can put in the m30) but the chip and injectors are plenty. You will not believe the results.sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iTComment
uh, they are injectors, and you could run about 15 billion different varieties in your E30. Nothing BMW specific about them. ;)
ebay is fine, just make sure they are design 3 or newer.
and for the last time, E30s never had MAFs, neither did M30s.Comment
I am just sick of people wanting to half ass stuff and go the cheap route then bitch when it fails.
I'm sorry, MAF=AFM my bad. Dyslexia on my part.
just picked up 4 24lb/hr's from fiveomotorsport.com - about $180 for the set, brand new.
this page helped me out when i was hunting for something with the right rate/fuel pressure:
past:
1989 325is (learner shitbox)
1986 325e (turbo dorito)
1991 318ic (5-lug ITB)
1985 323i baur
current:
1995 M3 (suspension, 17x9/255-40, borla)Comment
After doing a bit of searching it looks like it's more about injector design than injector size. Single pintle stock injectors have a crappy spray pattern and are probably old and clogged after 20 years of use not to mention intrinsically noisy, 17.5lb/hr M50/S50 injectors as well as 19lb/hr mustang injectors are 4 pintle (more efficient spray pattern), quieter and newer. That about sum it up?paint sucksComment
