A/C question need help!
  • der affe
    Technical
    • Dec 2005
    • 8452
    here is a pic of my old A/C comp.
    i just purchased a rotary A/C comp from Buddy (z31maniac) and i am getting ready to install it on my car. while i was doing a Z-3 A/C condenser fan up grade, since i was under the car, i took a good look at my old one with the new one. the new one is longer and the line are in a different spot, (no big deal, the lines will easily reach) i noticed that there was some sort of a pressure switch??? in the actual body of the orginal compressor. can i just bypass it, as the new one does not have one? the wire is there for the A/C clutch, but there is nothing else.
    any help would be great!
    thanks,
    Greg
    and thanks buddy for the smokin deal on the comp!
  • der affe
    Technical
    • Dec 2005
    • 8452
    going to watch kickball bump
    • der affe
      Technical
      • Dec 2005
      • 8452
      anyone?
      my car has a 3-91 build date and the doner car has a 3/88 build date although it is not a factory a/c comp.
      • der affe
        Technical
        • Dec 2005
        • 8452
        wow.......no one has a clue or has ever run into this??????
        • jinshiyang
          • 6
          Very good
          thread insert helicoil
          • der affe
            Technical
            • Dec 2005
            • 8452
            Originally posted by jinshiyang
            Very good
            post whore much?
            • Edev
              • 3731
              Originally posted by der affe
              post whore much?
              Lol. Aimed towards a person who has 6 posts haha. But sorry I can't help, I guess I am just here for my post count.
              M Coupe
              • der affe
                Technical
                • Dec 2005
                • 8452
                ok this is the a/ccomp i have in the car now:
                http://www.realoem.com/bmw/showparts...07&hg=64&fg=50
                #5 is a temp switch. that is what i am asking about.
                my drier only has the one pressure switch in it unlike the illistration (#18)
                where is the other one?
                http://www.realoem.com/bmw/showparts...42&hg=64&fg=60
                and lastly how important is the temp switch? can i just bypass it or bridge it?
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  no one seems to have an answer so i keep bumping it.
                  not like i am saying "very good" WTF is that?
                  • equate975
                    • Jun 2004
                    • 3382
                    You need the temp switch, if you are pulling the AC apart you should replace the drier anyways. I suggest getting a dryer that has both switches on it.
                    #1 is not a dryer, its a baffle so there isn't a vibration the AC system.
                    Rollin' with a Geistkuchen
                    • der affe
                      Technical
                      • Dec 2005
                      • 8452
                      thanks, that answers my question.
                      i don't know why it did that 1 then smiley face crap when i put the number 18 in the post??????
                      • equate975
                        • Jun 2004
                        • 3382
                        You know what, IIRC it would just be another temp switch for the cooling fans. I wouldn't run an A/C system without pressure switches (i doubt you even can anyways) but I would say just try running it without the temp switch plugged in and see if it works.
                        Theres high side, and low side pressure switches that will turn the AC compressor off if there isn't adequate refrigerant or another problem in the system.
                        edit:
                        it looks like #18 there must have been 2 styles of driers, the switches would do the exact same thing, you would only have 1 not too. I don't know what I was thinking previously.
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          that is kind of what i was thinking, but i can't find anything that says it is a temp switch for what? (fans, temp too high causing too much pressure, like a back up for the high pressure switch)
                          i honestly don't have the cash for a new a/c drier right now either, so i would like to take my chances with the old one (i had been replaced 4 years ago, before i bought the car at the dealer)
                          yes, the system wont run without the pressure switches.
                          is this the only fan temp switch?
                          • der affe
                            Technical
                            • Dec 2005
                            • 8452
                            where is the same switch located if you have this style of comp?
                            http://www.realoem.com/bmw/showparts...49&hg=64&fg=50
                            this is the non behr/bosch type.
                            • equate975
                              • Jun 2004
                              • 3382
                              I would guess its somewhere else in the system. I know the pressure switches are used to cycle the pump, and the temp switch should be for fans. So either its elsewhere in the system, or for whatever reason it doesn't use one.
