how the hell do I remove this?
  • HardTech
    • 174
    The transmission is still attached to the engine in the car, but everything else has been dropped. I have easy access to this, but the little dowel pin refuses to come out. Any suggestions?
  • E30SPDFRK
    • 5706
    punch and hammer
    Byron
    Leichtbau
    • HardTech
      • 174
      I tried using a screwdriver to force it out, but it wouldn't move. There's not enough clearance for a hammer :(
      • e30serg
        • Dec 2006
        • 562
        Any way to tilt the transmission down some more? You have to remove that dowel.
        • HardTech
          • 174
          the transmission is already tilted down a little bit on a jack. The thing is, it's partially obscured by the vibration damper. I was able to cut the rubber parts on the vibration damper to remove the metal covering, but the part that remains still prevents me from getting a good angle to hammer it out.
          Is that the way to remove it? Just to hammer it out?
          • SamE30e
            • Sep 2007
            • 4319
            Bent hook and some patience.
            1985 325e 2.8 Turbo VEMS
            • Bey
              • Jul 2008
              • 479
              This thread might help. Looks like he just took a hanger and bent it.
              RIP
              • SamE30e
                • Sep 2007
                • 4319
                If you're lucky and it's not that stuck.
                • HardTech
                  • 174
                  I have a feeling it is stuck. EVERYTHING on my car has been an uber-bitch to get off. Plus, I took a narrow screwdriver and jammed it into the dowel, and it moved maybe a millimeter.
                  It should move both ways, right?
                  • LowR3V'in
                    • 4209
                    I've used two screw drivers.
                    • dj01540i6sp
                      • Jan 2009
                      • 349
                      Shifter Connector Pin
                      Is this a tapered pin that must be removed the same way it went in? Can you get a pair of Channel locks up in the area place a smaller pin/screw on it and press it out.
                      GL
                      • jrdeamicis
                        • Nov 2008
                        • 956
                        Be careful not to mushroom out the drift pin. You WILL hate life.
                        Past Car : E30 S50 6 Speed 5 Lug 3.73
                        Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                        ___________________________________________
                        BNB Designs
                        Engine Swaps, Fabrication, Innovation, General Repair
                        Richmond CA
                        Julian 848-248-8029
                        • paulkeith
                          • Apr 2009
                          • 146
                          i just did (tried...) this saturday night. i spent 30 minutes on it and then gave up. it was relatively slop-free so i just skipped that but replaced the rest of the shifter components.
                          I had the exhaust and tranny dropped but the driveshaft still connected. No way that thing was coming out with a bent coat hanger.
                          pull: '02 F-250 7.3L 6SPD 4x4, Chipped, Straightpiped, BFG MTKM2.
                          turn: empty stable. lame.
                          • 318isbmw
                            • Nov 2005
                            • 2841
                            I'm pretty sure there's no way its simply a slide in or out type of a deal . There would be no reason for it to stay in when driving for thousands of miles. Did you try pushing from both ends?
                            • deutschman
                              • May 2008
                              • 5958
                              pressing it out with a c clamp?
