19# injectors sans chip
  • thedeal
    • 643
    I am curious, can I run my m20b25 with 19# injectors w/o a chip for now. I plan on chipping it I just don't have it at the moment But I have the spare time to do the injector swap later this week. Will this Eff up my system?
    Thanks
  • Wh33lhop
    • 11705
    Well yes, you will just run rich as sin.
    paint sucks
    • 884door
      • Nov 2008
      • 380
      Pretty sure it'll run like crap at first but I think the ECU will adjust and make it work.
      • Wh33lhop
        • 11705
        It can only adjust within certain parameters.
        I doubt it will run as well as with stock injectors, even if you give it ten years of adjustment time. But it will be bearable for the time being.
        Just cough up the cheddar for a Mark D.
        paint sucks
        • tjts1
          • May 2007
          • 1851
          If the M42 can handle 22 and 24# injectors without running "rich as sin" on the stock chip, I think you'll be fine with 19# injectors in your M20. You'll only run rich in open loop which is exactly the point.
          • 884door
            • Nov 2008
            • 380
            I agree 100%
              • 34839
              the M42 comes with 19# stock though
              M50 injectors (17#) are a better match for an otherwise stock M20, plus you still get the superior 4 pintle design.
              • Kruzen
                • Mar 2004
                • 5603
                I run it and haven't had the time/opportunity/placetowork to throw in the m30 afm and buy a markD chip.
                I have pretty horrible gas mileage around town, highway is still good, haven't really noticed any gains, when the ECU is acting happy its a bit peppier than I remember it, but it could all be placebo.
                /shrug.
                Who doesn't love a little BBQ?
                Griot's Garage at a Deep Discount
                • zaust
                  • Jan 2007
                  • 200
                  The m30 afm will make no difference at all what ever map or injectors your running. stick with the stock injectors and get a map/chip and a big bore throttle body, much more benifit to you. You will also see a big benifit from removing the water from the bt too, just join the pipes together.
                  325i touring, 327i 2 tone tech 2, 335i tech 1 touring with nossigpic
                  • AlarmedBread
                    • Sep 2006
                    • 1510
                    It will run like shit, this is w/ m30 afm, but the stock afm was the same, very rich, no power, very poor fuel economy. Wait to do both injectors and chip at the same time. Alternatively you could try 19lbs + e85. I have been running that for a while without problems, but have no conclusive results or a dyno.
                    • deathtomine
                      • Jun 2008
                      • 206
                      bt???
                      • mojorising
                        • 62
                        I think he means tb as in throttle body? Those of us in warm climates can probably take the throttle body coolant lines off, I am pretty sure they are only used to keep the throttle from freezing in the cold temps. That and they probably warm up the intake temp a bet once the motor is warm.
                          • 34839
                          the temperature most likely to see ice formation is apparently ~70 degrees.
                          also, with as small of a surface area as the TB is, I doubt it would make any difference. the air is moving through the TB at a high speed and into an intake manifold that is just as hot and has lots more surface area.
                          • T Verdier
                            • Aug 2007
                            • 2636
                            So the ecu doesn't adjust for the injectors because they are design 2/3 and not design 1 like the stock #14
                              • 34839
                              nope, that has nothing to do with it
                              design 2/3 just have more pintles and a far superior spray pattern
                              electically, they are exactly the same. The ECU cannot tell them apart, except that with O2 sensor feedback it has to dial back the pulsewidth to reach it's 14.7:1 target.
                              the ECU has long term and short term fuel trims. the short term trim adjusts the injector pulsewidth in real time to keep it as close to 14.7:1 as possible. the long term trim adjusts a global base pulsewidth value based on how much it has to adjust for the short term trim. It only works with a functioning O2 sensor.
