Sunroof Gasket Adhesive
  • Japandrew73
    • 2164
    When removing the sunroof gasket, and moving it to a different sunroof (or moonroof in my case) is it necessary to use any kind of adhesive?
    When I had my sunroof out the other day I peeled back the gasket just slightly to see how it went on and it seems like it fits snugly into place, however, there is a small, barely sticky adhesive under the gasket. Is this something in particular or do you think I could get away with simply pushing the gasket into place snugly?
  • Japandrew73
    • 2164
    • TexasTerp
      • Jan 2009
      • 3541
      Are you talking about the seal (felt on top) that attaches directly to the sunroof? If so, I bought a brand new set and just had to push it on, it was difficult but no adhesive necessary.
      I haven't had any issues with leaks or anything, and it's rained pretty hard here in MD since I put it on.
      stephenbrody.com
      • Japandrew73
        • 2164
        Perfect! Just the answer I was looking for. Thanks
        • AlpineIS
          • 161
          +1. No adhesive required.
          • der affe
            Technical
            • Dec 2005
            • 8452
            if you are worried about it you can use a bead of 3M weather stripping adheasive. it comes in clear, yellow and black. you will hear people call it gorilla snot...for good reason!
