Gauging Interest in Hood support solution
  • oekundar
    • Sep 2007
    • 964
    I'll let the pictures do the talking:
    The piece/unit uses the stock mounting points and would fairly inexpensive...around $25. Working on some mods for it already, but it beats the stock support and still allows the hood to still properly close.
    Thoughts?
    BMWCCA #389756
  • kencopperwheat
    King of Kegstands
    • 14396
    What's wrong with the shock? Mine works perfectly.
    Originally posted by Gruelius
      • 34844
      I hate hoods with the stupid prop up stick, usually on POS japanese or american cars. :p
      how much is a new hood shock? Mine is orignal and works fine, but my hood is pretty light. I have a spare from the parts car that works fine too.
      • oekundar
        • Sep 2007
        • 964
        while mine works at times, it was certainly not all that stable. I'm sure there are others that can attest to some bruising caused by the stock shock.
        BMWCCA #389756
        • everlast
          • Oct 2004
          • 225
          I'd use of one these when I'm working on the car, but then I'd put the stock shock back on for normal use.
          The issue with a solid prop is that if you (or someone else) is used to the shock, you get a pretty rude surprise when you pull the hood down with the solid prop in place. :o
          • GotCone?
            • Jan 2008
            • 589
            replacement shocks are cheap. $10-13
            Build : Das Drehmoment Ungeheuer
              • 34844
              you probably just need a new one then
              • oekundar
                • Sep 2007
                • 964
                Once one makes a concious effort to remember the prop, it works....its not for everyone...shoot it may not be for anyone...thus the thread. :)
                BMWCCA #389756
                • StereoInstaller1
                  GAS
                  • 22679
                  The stock hood shock working SO well is one of the best things about working on the E30s.
                  I would be pissed if someone put that on my car.
                  Closing SOON!
                  Thanks for 10 years of fun!
                  • oekundar
                    • Sep 2007
                    • 964
                    good info
                    agreed...but why buy a new one when you have a piece of aluminum in the garage? :D
                    BMWCCA #389756
                    • e30evolution
                      West Werks
                      • 1888
                      That is an amazing idea.... i will install 2 in my car
                      http://www.westwerksauto.com
                      • everlast
                        • Oct 2004
                        • 225
                        To reinforce the OP's idea: you've never experienced joy until you've had the car jacked up at the front with the hood open and shake the car, having the hood come down on you.
                        If the wheel assembly at the corner had hit my head I very likely would be dead.
                        So this = good idea.
                        • mattdk318i
                          • Jun 2006
                          • 3953
                          mine works well too, I just use a cloth and visegrips on the hood shock to keep it from falling.
                          No damage comes to the shock rod.....and its been working for years.
                          • daniel
                            • 6703
                            i think you should work on making it double hinged instead, so it can open either direction.
                            http://instagram.com/dslovn.drives
