Stomp test code 1888?
  • T Verdier
    • Aug 2007
    • 2636
    I
    I'm getting 1888 how do I find what the code is?
  • e30this
    • 3580
    Find information, resources and relevant links for e30world.com. This domain may be for sale.
    ITs not in there but thats all I found....
    • tuNED318
      • 179
      how do you get 1888? http://www.unofficialbmw.com/repair_faqs/motronic.html
      sure you have an e30? :P
      RACE | RAT | RETRO | RADICAL | EURO
      • T Verdier
        • Aug 2007
        • 2636
        Yeah it's funky right? Alright here's the whole story.
        I instaled my miller maf kit and war chip, following directions completly and doing everything with the best quality you can do. I drove around all day it felt great I got to my friends shop and hung out then drove home and all was fine until I got gas. One I turned my car back on I got CEL so I get home and make sure I pluged the maf in right and it was fine the first code that was being flashed was 1211 or DME Wich is the ecu right?
        I unplaged the battery checked my ecu harness and Plug it back in and the check engine light was still on.
        This time it flashed 1888. I'm not tripping!
        Eventualy it went off. But when I was sitting there idling for a minute it came on but when I gave it some gas it went off.
        • der affe
          Technical
          • Dec 2005
          • 8452
          are you shre it wasn't throwing a 1221 code?
          that is the code for an o2 or MAF problem, but it also means that the mixture is off or out of spec. i get that everyonce in a while when i start screwing with the mixture when it gets extra hot or cold here or when i have it too rich and the cam causes it to load up at idle.
          rememember that i also have a MAF conversion (but a split second/T-bird one) so we may be having similar problems.
          • T Verdier
            • Aug 2007
            • 2636
            Yeah it sucks I have no way of knowing if I'm running rich or lean. It does seem to warm up fast.
            • der affe
              Technical
              • Dec 2005
              • 8452
              you need to get atleast a narrow band gauge
              • T Verdier
                • Aug 2007
                • 2636
                My friend said that a narrow band is just like a light show going off. How much would a wide band o2/ afr be?
                • OrganicMechanic
                  • Jan 2008
                  • 1719
                  linky
                  I love this wide band----
                  join the E30 Cabrio owners gruppe
                  click here for details
                  • der affe
                    Technical
                    • Dec 2005
                    • 8452
                    they are around $200.00-$300.00
                    here is the part number for the bosch 02 sensor you will need. 17014
                    PM forced firebird for the site where you can get a kit for the gauge and box all on the cheap. IIRC everything included under or around $100.00
                    • der affe
                      Technical
                      • Dec 2005
                      • 8452
                      Originally posted by OrganicMechanic
                      linky
                      dam! that's nice!
                      • OrganicMechanic
                        • Jan 2008
                        • 1719
                        T/Y
                        I used it to tune my 11 sec GVR4.
                        just realized that I hit #1000 on the post count!!!
                        where my prize?
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          the check is in the mail!
