IS lip Splitter?
  • asheridan07
    • Oct 2007
    • 224
    IS lip Splitter?
    Does any one know were to get a IS lip splitter?
    Thanks
  • namsayin
    • 1568
    Ryan G on e30 tech has em!
    • Ral
      • 1486
      he's also here too. Every once in a while his banner will pop up in the upper right.
      sigpic89 M3
      • spooledtt
        • Jun 2008
        • 420
        Ryan G for sure. His name on r3v is m3 ryan.
        • asheridan07
          • Oct 2007
          • 224
          Thanks dudes! I'll PM him
          • cferb
            • 1442
            Plastic store and make your own ;) that's what I did
            • SL a.m.>IN
              • Jul 2009
              • 251
              cferb how exactly did u do it? Do you have pics?
              It looks really good from your sig
              • george graves
                • 20003
                Ryan G. His user name is "M3 Ryan"
                Originally posted by Matt-B
                • TexasTerp
                  • Jan 2009
                  • 3541
                  To get the bend correct it's a PITA! Especially if you use thick ABS (3/4") plastic like Yun and I did for the ones we sold. Ryan G uses 1/8" ABS which is much thinner and a bit easier to work with but is significantly less sturdy. Then again you're only going for looks so it doesn't really matter.
                  stephenbrody.com
                  • george graves
                    • 20003
                    Not so sure I'd want a 3/4" splitter! ;)
                    I've seen Ryans, and they are thicker then 1/8", they might 1/4" I'd say from eye-balling it.
                    • kamotors
                      • Nov 2007
                      • 7102
                      Ryan G's are 1/8" and its plenty thick enough.
                      7speedshop.com
                      • Alkasquawlik
                        • 4557
                        I have a Ryan G splitter and that's the only person who is selling them at the moment, unless you make them yourself.
                        SC*AR
                        Originally posted by JamesE30
                        And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
                        • cferb
                          • 1442
                          I made mine a little different, flat across the bottom, the bend is an extra insert. If you make one, definitely bend first then cut the shape though, or start with a generic shape with lots of extra room. It's just ABS plastic, and use a heat gun to bend it.
                          If I were to do it again I'd make it thicker(it warped in the sun) and stick out further. I also wouldn't have made it entirely by hand with shears and a sander.
                          • thereisnoyun
                            • Feb 2007
                            • 2301
                            hahaha 3/4. I dont even think you can bend that.
                            ryans is about 1/2 the thickness that we use.
                            Ours is 3/16
                            ryans is probably 1/8
                            there really isnt a size in between that you can buy at the plastic store.. at least the one I went to, so its either 1/8 or 3/16. ours is 3/16, that means his has to 1/8,
                            The biggest difference not only the thickness, but how far it reaches back, ours reach all teh way back to teh end of the splitter, ryan's come up 2 inches short from the end of hte is lip. Ours is a heck of structural reinforcement of hte lip. I never used his, but from the looks of it, its purely cosmetic. Too thin and too short to provide any reinforcement.
                            though we arent actively marketing this anymore and its a pita to make them, I'm not bashing anyones product, but if we cut them like ryan's we can cut around 8 per sheet of 8x4 plastic, where the way we cut them, we can only cut 4.
                            and good luck even getting ryan to make any, I originally jsut wanted to buy from him, but after 3 month of waiting, I just made my own.
                            • TexasTerp
                              • Jan 2009
                              • 3541
                              well clearly I suck at life as I didn't even notice I put 3/4!!!
                              stephenbrody.com
