car talk says double clutching is bad?
  • daniel
    • 6703
    i've been double clutching for a few years now... then i hear that it is actually bad for the car to do so from the car talk guys. here i thought i was saving the clutch from unnecessary wear. i figured downshifting (say from 3rd to 2nd) then letting the clutch out to get that lurch feeling was just extra, unneeded wear on the clutch.
    discuss.
    http://instagram.com/dslovn.drives
  • gtdragon980
    • Jun 2008
    • 1808
    i never really understood the point in double clutching....and doesn't rev-matching eliminate that lurch when downshifting?
    FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
    Originally posted by scabzzzz
    I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
    1989 325i - Project/weekend driver
    2002 325i - DD
    2005 Suzuki SV650 - Toy
    • meidlin
      • 30
      Double Clutch:
      Masturbating with one hand while intentionally cutting off oxygen to the brain with the other hand for the purpose of sexual gratification. See also Auto Erotic Asphyxiation.
      ... Wait, What?
        • 34839
        learn how to rev match, you don't drive a 1960s pickup with no synchros in the transmission.
        • Joe318is
          • Sep 2005
          • 6451
          helps with worn out syncros
          Originally posted by vlad
          • BenM
            • 2184
            What?
            Double clutching doesn't have anything to do with prematurely wearing the clutch. It is a technique used when driving older cars that do not have synchros (say a 1948 Ford F5). Double clutching on a newer car with perfectly good synchros is silly.
            edit- nando beat me to it. :P
            Originally posted by BillBrasky
            E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
            1991 318i Alpine II - S50/5-lug swapped - track car
            1989 325i Cirrusblau - Daily
            1970 2500 - Malaga over Grey Cloth
            2012 F350 6.7PSD
            • TDE30
              • 7042
              This.
              - Trey
              E90 325i/6 (ZSP, ZPP, ZCW)
              E36 325i sedan
              E30 325i sedan
              Volvo 945T
              • daniel
                • 6703
                revmatching eliminates the lurch but puts wear on the synchros. there is something extremely satisfying about doubleclutching and effortlessly slipping into a lower gear with no resistance.
                i don't think ill ever stop doubleclutching since it is just naturally what i do now, but i wanted to hear what others thought about the idea. the car talk guys specifically said it wears out the clutch faster, which doesn't make sense to me.
                  • 34839
                  Well there's no harm in doing it, but as far as saving the synchros, I'm not sure it's needed unless they are already bad. I have 260k on my getrag 260 and all the synchros are fine, I know there are lots of others who could say the same.
                  I think knowing both methods would be beneficial. If you ever do any HPDEs, you'll want to know how to rev match. Just last week I was watching a video of an E30 with a seriously built engine, but the driver was just letting out the clutch to downshift and nearly spinning out on ever corner entry.. yikes!
                  • Wh33lhop
                    • 11705
                    I do it too, effortless downshifts are very satisfying. I've found, though, that it's easier to rev match smoother lurch-wise than it is to double-clutch, just because the object of a double clutch is to match the revs in neutral (then perform the second clutch, clutch in, complete the shift, clutch out--more time for revs to drop) whereas in rev-matching you tend to have the revs matched right as you're releasing the clutch.
                    It's also nice to be able to double-clutch into first, just to be a jackass coming to stoplights :p
                    paint sucks
                    • Hallen
                      • 1008
                      I would suspect you are doing putting more wear in both the throw out bearing and the clutch by double clutching. In double clutching, you are engaging the clutch twice during each shift. The clutch and the flywheel will be spinning at different rates and every time the clutch squishes up against the flywheel, you are going to get wear.
                      Rev matching is the ticket. If you minimize the speed difference between the clutch and the flywheel and you minimize the length of time the clutch spends spinning against the flywheel, the less wear you are going to have. Think about it: you burn a clutch up by trying to feather the clutch while accelerating. You get more wear by doing that than you do if you rapidly engage the clutch causing a bit of a jerk (which can be eliminated with good rev matching). But the clutch spins less so you are doing as much to it. Anyway, that's just my take on it.
                      1987 E30 325is
                      1999 E46 323i
                      RIP 1994 E32 740iL
                      oo=[][]=oo
                      • Wh33lhop
                        • 11705
                        The phrase you are looking for is heel-toe :p
                        There's a video of an engineer test driving the E92 M3 around some track chirping the tires on every downshift. I cringed.
                        Or there's this tool:
                        Fucking ugliest S38 swapped E30 on the planet whose owners abuses a slipping clutch and can't even heel-toe.
                        paint sucks
                          • 34839
                          that's the common name for it, but since I don't actually use my heel, rev matching is a better term. It's more like pinky toe/ball of foot. ;)
                          • delfin
                            • Nov 2007
                            • 1064
                            Can someone explain exactly what double clutching is?
                            Advanded Delphin Division
                            My e30s: 1987 325i/1994 318iT
                            • daniel
                              • 6703
                              car in 3rd gear, 3000 RPM. push clutch in, shift into neutral. release clutch, which matches the transmission speed with the engine speed. rev up to 4000RPM, push clutch in, and smoothly, creamily slip the shift lever into 2nd gear, then let the clutch out.
                              its all about knowing the RPMs in each gear for a given speed so you can shift between gears and adjust the RPMs accordingly.
                              btw if you ever want to drive without the clutch, you do a similar thing, except you don't use the clutch.
