Doh, should I pull it back off?
  • z31maniac
    • 17566
    I realize after we torqued down the last bolt on the flywheel last night, that we didn't get that big circular washer in there between the bolts and the flywheel.
    Pulling it back off isn't that big a deal, I'll just need to order more flywheel bolts and wait for them to show up since these have already been tightened down.
    Or would just throwing some red loctite on them be sufficient to reuse?
    www.gutenparts.com
  • shiboujin
    • Feb 2006
    • 2791
    I reuse flywheel bolts all the time... lol... never had a problem. *shrugs* if you want to be safe id get new ones then. I'm not sure the starter will mate up 100% without that ring.
    • z31maniac
      • 17566
      ^Does that spacer go between the flywheel and the engine or between the flywheel and the bolts?
      If it's between the flywheel and the bolts, it wouldn't change the orientation of flywheel vs the trans.
      www.gutenparts.com
      • shiboujin
        • Feb 2006
        • 2791
        http://www.realoem.com/bmw/showparts...37&hg=11&fg=20
        My guess is in front of the flywheel. Hmm.
        • catchuk
          • Jan 2008
          • 344
          im quite sure its between the flywheel and bolts, the other way would be a nightmare to get them on and i dont remember dealing with that.
          • iflytii
            • Jun 2004
            • 482
            Goes between the flywheel and bolts. What flywheel are you using?
            • z31maniac
              • 17566
              M20 kindly sir. Had it lightened and machined to fit the E34 pan.
              What do you think on the bolts? New or reuse?
              www.gutenparts.com
              • iflytii
                • Jun 2004
                • 482
                I'd just reuse them. Slather some red loctite on them and torque them back down.
                • z31maniac
                  • 17566
                  Damn that shim! Oh well at least I realized it before we had the clutch and trans bolted up!
                  www.gutenparts.com
                  • 3bvert
                    • 1032
                    how come red, isnt red for mega torque and require heat to sometimes remove
                    at least tahts how we use it on tractors on the farm
                    red for big nasty abuse
                    blue for anything else
                    • E30FreaK89
                      • Apr 2006
                      • 437
                      i forgot to put mine on when i did my 5 speed swap! I didnt realize it till i was all done and cleaning up. But my car shifts fine and works great..
                      • lifeiskaos
                        • 1709
                        it's pretty much only there to protect the surface of the flywheel from the heads of the bolts. i suppose it might distribute the clamping force more evenly, but in any case it's not vital for those of you who dont have one :)
                        • jackbenny
                          • 414
                          Having done this same job this past weekend, it was a relief to see this phrase. I've never struggled so much getting a transmission back on the engine, I would hate to have take off again!
                          -Josh
                          Check out my build thread...
                          http://www.r3vlimited.com/board/showthread.php?t=131055
                          Need parts? Support the community!
                          http://www.gutenparts.com
                          http://www.blunttech.com
                          • iflytii
                            • Jun 2004
                            • 482
                            Buddy has a lightened flywheel, will likely have cams and undoubtedly will have a chip raising his rev limit. With the issues many racers are having with bolts backing out from harmonics related to those specific mods, I would not hesitate to douse those bolts in red. Of course he may never have an issue but it's better safe than sorry in my opinion. A good impact gun will zip those red loctite covered bolts right out.
                            • z31maniac
                              • 17566
                              Bob, if that shim is purely there to protect the surface of the flywheel, do you think leavng it out would be better? More threads of the bolts would be engaged that way.
                              www.gutenparts.com
