Overheating!Help
  • TurkE30
    • 272
    Overheating!Help
    Hey guys i got a '89 325i, its been overheating lately so i dont drive as much, today i decided to go around the block and i went about 200 yards from where i live and the car instantly overheated really bad, i got back to my house checked the waterpump and the coolant in it was still cold im thinking the coolant just gets stuck somewhere or something. what do you think the problem is? thank you for your help!
  • red325
    • 961
    hmmm.....
    had this same problem on my dad's mercedes clk. It's not that your engine is actually overheating, there's just a problem with the temperature gauge/reading system. Or at least that's what it was on the Benz. I'm not sure how to fix, seeing as he just took it to the shop, but I'm sure someone on here will.
    • wolfgangstbd
      • 960
      on our cars that would just be a bad temp. sensor but that would also cuase the car to run rich/lean if it was indicating hot/cold tempatures. you could have a bad thermostat or temp sensor if you have been noticing your car running a little wierd
      • red325
        • 961
        True that, the Mercedes that had a bad temp sensor ran very differently and cut out alot
        • TurkE30
          • 272
          im guessing its my thermostat, im going to replace it tomorrow and see what happens.
          • equate975
            • Jun 2004
            • 3382
            It either is overheating, and I would guess your WP is shot. Or its not, and is just a bad temp sensor.
            Rollin' with a Geistkuchen
            • TurkE30
              • 272
              Im sorry but what is a WP?
              • Wh33lhop
                • 11705
                Water pump
                paint sucks
                • blunttech
                  • 12850
                  have you done anything to the coolant system recently that could have caused an air bubble? changed fluid,hoses etc etc? is the heater blowing cold when on full blast?
                  sales@blunttech.com
                  www.blunttech.com
                  Like us on Facebook
                  • rThor432
                    • Feb 2007
                    • 3907
                    Either the solder joints on the SI board are cracked or the temp sensor is toast (both are likely). The car shouldnt overheat after being driven 200 yards, even if the water pump wasnt turning.
                    But, like Blunt suggested, if you did work to the coolant system shortly before the issue presented itself, it could be as simple as bleeding the system a bit more extensively.
                    • TurkE30
                      • 272
                      No i didn't do anything to the coolant system at all. i just filled it with a little bit of coolant thats all. I should also replace my temp sensor while im at it. and if that doesnt work i will keep you guys updated. Thanks alot guys for the help.
