Handy tip for adjusting valves
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    I just learned this from my father who used to do this on old Ford V8s.
    It can be frustrating trying to track down 1 or 2 noisy valves. And when there is wear on the tappets, gauging the gap to 0.010" may not actually lead to the correct gap. The solution is to be able to check valve clearances while the engine is running. But how?
    The m20 engine will run with the valve cover off! Who knew? I always assumed that because the engine runs on a vacuum it wouldn't run at all (or barely run) with the cover off. Wrong! I was also worried that it would spray oil everywhere but that didn't happen either.
    Once I had the cover off and the engine running, it was very easy to stick a 0.002" feeler gauge in the gaps of all the valves. If the valve quiets down you know it's set improperly. It's also much easier to find the noisy valve as you can do the old shadetree stethoscope trick and put a screwdriver on the rocker covers while holding the handle up to your ear. I was instantly able to identify which valves were noisier and tighten them down a thousandth or too.
    Voile! My valves are quieter than ever and properly clearanced. The engine sounds perfect! Hopefully this tip is useful :up:
    Now if you're concerned that your valves are too tight, obviously you need to check all of them the old fashioned way. But valves loosen over time, they don't tighten. So unless your valves were improperly set the last time they were adjusted, you should not ever have to worry abut them being too tight.
    • 34844
    I haven't tried that, but I do like adjusting them with the engine hot a lot better than doing it cold. but you have to be fast, if you take too long it cools and they will be set too loose. and try not to burn yourself of course.
    • jonmon6691
      • Aug 2009
      • 252
      Where do you stick the feeler gauge if the tappets are moving 700 times a minute?
      <-- F*** that guy
      • gtarwiz
        • Jan 2009
        • 591
        sounds interesting. I need to try that the next time i adjust my valves.
        BMWCCA # 482566
        Originally posted by nando
        also, I can't think of any BMW special tools you need to do a headgasket on an M20. you could nearly do it with the trunk tool kit, some bubble gum, and string.
        Check out my Leather Shift Boots for Sale Here
        Check out my other work with my GF Here Great gifts for your Wife or GF
          • 34844
          they actually move at half that speed.. but, I think he probably means turn the car off, put a shim in there, and then start it again.
          • CorvallisBMW
            • 13039
            nope. Do it with the engine at idle. Trust me, it's not hard :)
            the camshaft runs at 1/2 engine speed. Divide that by 60, and each one actually activates only about 5 times per second. It sounds fast, but really it's not. You shouldn't have any problems.
            • EricT
              • 702
              I think I may just give it a go this weekend. I adjusted my valves two weekends ago and one still sounds a little noisy...certain its only one tho. Thanks for the tip.
              BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
              • jonmon6691
                • Aug 2009
                • 252
                Can you take a video when you do it?
                <-- F*** that guy
                • TexasTerp
                  • Jan 2009
                  • 3541
                  Very interesting, I need to adjust my valves when I get back in DC. I'll definitely try this out!
                  stephenbrody.com
                  • thedeal
                    • 643
                    Great advice! Mad props to you CorvallisBMW. I will definetly use this when I adjust my valves next week. Do you need a new valve cover seal every time you remove the cover?
                    • OrganicMechanic
                      • Jan 2008
                      • 1719
                      I was gonna try and get techinical but now I can`t think how to express the math on a key board.
                      The cam is spinning slow enough to slip a feeler in there when in motion.
                      not really new since your pops showed it to ya, but new to this generation of DIYer`s--was it an awsome moment for your dad when you had that "ahh ha" face?
                      join the E30 Cabrio owners gruppe
                      click here for details
                      • deansbimmer
                        • 674
                        Great tip!!
                        A+ would read again
                        • Disaster Inc
                          • Oct 2007
                          • 429
                          Hey great tip!
                          I've been obsessed by the valve adjustment ever since I've owned an M20. Probably done em 30 times in the last two years, hot, cold etc.
                          Have had trouble accepting the noise as normal, coming from hydraulic tappet V8s. Finally last week switched from synthetic to dino 20-50 and it sounds the best it ever has.
                          I'll be trying this one tomorrow!
                          • AndrewBird
                            The Mad Scientist
                            • 11898
                            Chevy's are easy to adjust. A single nut holds the rocker arm on, so all you do is loosen it up a 1/2 turn, then slowly tighten it back up until the clatter goes away. No stupid eccentrics to adjust or nothing. There are actually clips that snap onto the rocker arms to deflect oil from shooting out at you too.
                              • 34844
                              porsche rockers work the same way.
                              the eccentric adjustments are pretty poor, actually. and the fork of the rocker arm leads to failures..
