Need help re: Recaro seats
  • reelizmpro
    • 9541
    Guys I need your help. I need to know if all bottom mount Recaro's have the same seat bolt pattern. 2 bolts in front about an inch from each other and 1 bolt on the back for a total of 6 bolts. From what I've gathered so far they are all like this. Just want to confirm this is the standard Recaro pattern.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
  • der affe
    Technical
    • Dec 2005
    • 8452
    for the most part yes.
    what seats are you trying to adapt?
    • reelizmpro
      • 9541
      I'm not, just trying to settle something. Do you know of a bottom mount Recaro that has a different pattern?
      88 M3 - LACHSSILBER
      • der affe
        Technical
        • Dec 2005
        • 8452
        every reclining back one i have ever seen has the same bolt pattern EXCEPT the VW "corrado" ones that have tyhe single center rail and a different seat bottom. the center rail is welded to the bottom of the seat and the actaul seat bottom is different too.
        • Brian 89 325i
          • 1450
          All of the ones I've ever seen look like that. Unless they are an OEM seat, then its anybodies guess.
          • der affe
            Technical
            • Dec 2005
            • 8452
            are those mustang recaros in the pic?
            • ///m3
              • Apr 2006
              • 563
              correct
              BMW Headlights ::
              • reelizmpro
                • 9541
                Any of you gentlemen see a reason why these wouldn't work?
                88 M3 - LACHSSILBER
                • namsayin
                  • 1568
                  I had custom adapters made by a friend, and i only used the 2 front bolts and 2 rear bolts.
                  two cylindrical pipes for the rear, and a t-shaped flatbar up front with washers to secure it. I used a 1/8" thick flatbar to secure the bottom of the seats
                  • AC Nico
                    • 3619
                    are those original recaro brackets?
                    *** For sale: euro stuff, BBS steering wheels, smoked tail lights, bunch of rare wheels (5x120 and 4x100) ***
                    [/color]
                    • reelizmpro
                      • 9541
                      They are OEM Honda brackets for Recaros. Just by looking at the bolt pattern does it look like they fit the above Recaros with the (3 bolt on each side pattern) I already know the answer but just asking for opinions.
                      88 M3 - LACHSSILBER
                      • namsayin
                        • 1568
                        what JDM recaros are you using?
                        • reelizmpro
                          • 9541
                          Mitsubishi Recaros that were used in a DC Integra
                          88 M3 - LACHSSILBER
                          • namsayin
                            • 1568
                            ^ nice choice!
                            • Wh33lhop
                              • 11705
                              Then why the hell are you asking?
                              paint sucks
