how do i check an M70 ?
  • flyboyx
    • 8371
    i would not buy this for an e30 personally, but it is a cool engine. if you can't resist, take the oil cap off first and look in there and see if the internals are clean. if they are, the car has probably had good maint over its life time. get a compression tester, battery and a pair of jumper cables. pull the plugs. run the cables to a good ground on the engine and to the positive starter terminal lead. bump it over a few times and check the compression in all the cylinders. i would throw 2 quarts of oil in it if i were you.
    Gigitty Gigitty!!!!
    • Xat1cZ
      • 2020
      I feel like I'm the only one noticing the date when this thread was started..
      • FunfGan
        • Jan 2011
        • 4958
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • Swanny
          • Mar 2012
          • 2834
          Doh!
          Swanny!
          SUCKERS.
          • F34R
            sLaughter
            • 12385
            Someone bumped it before me, must have removed their comment. I did not go searching for an m70 thread haha.
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • flyboyx
              • 8371
              yeah....sure you did. 8)
              Gigitty Gigitty!!!!
              • Xat1cZ
                • 2020
                I beliiiieve yooouuu... I'm sure you were just trying to figure out how to mend 2 m20's together ;)
                • slammin.e28
                  שמע ישראל
                  • 12054
                  How do I check the date on a thread...?
                  Fail.
