Car runs super rich post motor swap - ideas?
  • Turf1600
    • 9815
    I put a new m20 in my 90 325is after my old motor got flooded. The car will start up and stay running if I manipulate the gap pedal - but it won't idle at all. Also, I'm getting a pretty heavy gas odor out of the exhaust. Anyone have any ideas? I swapped the wiring harness and TB off of the old motor.
    TIA
  • blunttech
    • 12850
    temp sensor. try swapping it out with the old one
    sales@blunttech.com
    www.blunttech.com
    Like us on Facebook
    • Turf1600
      • 9815
      Which one? on the radiator or near the t-stat housing?
      • Dave
        E30 RAT
        • 11675
        t stat housing. The one on the radiator is just for the fan
        Current Cars
        2014 M235i
        2009 R56 Cooper S
        1998 M3
        1997 M3
        • Turf1600
          • 9815
          Ok cool thanks.
          • Jean
            • 18228
            +1. Make sure you replace the one for the ECU and not the gauge cluster :)
            The ones in the radiator are just on/off switches.
            • Turf1600
              • 9815
              So both of them?
              • Jean
                • 18228
                No, I was just saying make sure you replace the right sensor as one is for the ecu and another for the temp gauge.
                • Naplm00
                  • Nov 2008
                  • 1573
                  check the connection to the AFM
                  when mine comes loose (due to bad connector) car will run rich and not idle
                  88 325ic ~~~> Rusty and ugly
                  85 E ~~~> RIP
                  • Turf1600
                    • 9815
                    Since the car flooded is it possible that the AFM is fried?
                    • backtrail69
                      • Jul 2005
                      • 4471
                      very likely considering how craptastic they are to start out with, especially if the car injested water.
                      :: PNW Crew ::
                      '87 325 4dr, '74 2002
                      • Turf1600
                        • 9815
                        Swapped AFM made no difference. I'm wondering if I mixed up the fuel line and the return.
                        • george graves
                          • 19996
                          How's your o2 sensor? Do you have a cylinder not firing?
                          Originally posted by Matt-B
                          • backtrail69
                            • Jul 2005
                            • 4471
                            check to make sure the diaphragm in the FPR isnt dead too
                            :: PNW Crew ::
                            • Turf1600
                              • 9815
                              02 sensor stayed on the car - it was newish. The FPR is from the 60k motor - I heard it run when I bought it.
