Car runs super rich post motor swap - ideas?
  • Turf1600
    • 9815
    How's your o2 sensor? Do you have a cylinder not firing?
    It sounds like there may be a miss at low RPMs. The car revs all the way up to the redline it just won't idle and it's running rich at low rpms.
    • BenM
      • 2184
      sounds like a vacuum leak.
      Originally posted by BillBrasky
      E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
      1991 318i Alpine II - S50/5-lug swapped - track car
      1989 325i Cirrusblau - Daily
      1970 2500 - Malaga over Grey Cloth
      2012 F350 6.7PSD
      • Turf1600
        • 9815
        The valve cover to TB hose is new - all hoses to the charcoal cannister are tight - the hose to the brake booster is present. What else is there?
        The fuel lines are correct. The spark plugges are fouled.
          • 34834
          Originally posted by Turf1600
          Swapped AFM made no difference. I'm wondering if I mixed up the fuel line and the return.
          if you did that it wouldn't start unless your FPR is blown.
          have you put in a new coolant sensor yet? that is most likely to make your car run very rich, other than the AFM.
          • george graves
            • 19992
            Now's about the time I'd go drive the piss out of it to get a better feel for what it's doing.
            Originally posted by Matt-B
            • Turf1600
              • 9815
              I swapped one of the sensors - the one nearest the front of the engine bay. I can't get to the other one. Which controls the ECU?
              • blunttech
                • 12850
                spray carb cleaner around that fucking vent tube that connects the intake to the crankcase while its running to check for leaks. in fact spray that shit everywhere at idle.. did you remove the intake when you swapped?
                sales@blunttech.com
                www.blunttech.com
                Like us on Facebook
                  • 34834
                  I think it's the other one - blue connector?
                  • Jean
                    • 18228
                    Disconnect one of the sensors while the key is in ON position, watch the temp gauge. It will be the one that doesn't affect the temp gauge.
                    • Turf1600
                      • 9815
                      I got her going - but I might be cheating. I reconnected some things and drive her around - definately sounded better but still wouldn't "idle" unless I held my foot on the gas - but it still ran smoothly @900 rpms with no more gas smell. I just adjusted the cable to make it idle at 900 and voila...running car. I also changed the cheap autolite plugs to busch platinum fours.
                      • george graves
                        • 19992
                        Platinums blow in my experience - You'll run nice for about 200 miles - then they rob you of power. Keep an eye (or butt dyno) on them.
                          • 34834
                          did you ever change the coolant sensor? I don't know how I can be more clear. :p
                          Your TPS is probably misadjusted as well, since you messed with the throttle stop. that means the ICV doesn't turn on, which is likely why it died unless you held open the throttle.
                          plus, yeah - why are people still wasting money on platinums? I guess they're easier to find these days. plus multiple tip/v-groove/splitfire spark plugs = LOL
                          • Turf1600
                            • 9815
                            It was the AFM.
                            • Naplm00
                              • Nov 2008
                              • 1573
                              yay, knew it!
                              88 325ic ~~~> Rusty and ugly
                              85 E ~~~> RIP
