540i to e30
  • 318lotis
    • Sep 2009
    • 15
    540i to e30
    this may be a silly question, i inherated a wrecked 540i, would any parts off a 540i fit onto a e30 two door?
  • Alkasquawlik
    • 4557
    you could swap the engine.
    SC*AR
    Originally posted by JamesE30
    And with a car looking like yours I imagine the balance shall tip in the favor of insult, like a big fat fucking retarded fucking black girl on a see-saw, opposite... a dwarf.
    • vivalegreg
      • Apr 2006
      • 1313
      if and only if...you had a set of balls...you would take that hopefully intact drivetrain and swap it in your e30..
      tis what id do, and many others
      e30s r kool
      • OrganicMechanic
        • Jan 2008
        • 1719
        with losta work and welding.
        Everything fits everything.
        If it is a good runner, I have a 530i auto that you could buy for parts, or sell me a motor?
        keep in mind if you are wanting to do this in an E30, you need to use the V8 remote braking system. No firewall mounted booster will allow clearance.
        join the E30 Cabrio owners gruppe
        click here for details
        • Raxe
          • 5346
          What style of 540i? E34 or E39?
          • stegosaurus
            • 367
            If it's an e34 you could do the dome light swap.
            • 318lotis
              • Sep 2009
              • 15
              thanx for replys , Someone mentioned manifold intake swap, from 540 to e30 318is, is that possivble?
              • SamE30e
                • Sep 2007
                • 4319
                To put the engine in you need to weld mounts to the frame rails.
                1985 325e 2.8 Turbo VEMS
                • TexasTerp
                  • Jan 2009
                  • 3541
                  Engine swap!! Have fun modifying the transmission tunnel, that's a badass swap though if it's an m60!
                  stephenbrody.com
                  • Edev
                    • 3731
                    m62tu I think? Depending if its an e34 or e39
                    M Coupe
                    • daniel
                      • 6703
                      shift knob
                      http://instagram.com/dslovn.drives
                      • Julien
                        • 7472
                        sell 540i to me, yeah?
                        Build Threads:
