yes.
Differential Question
Originally posted by b*saint View PostHow do you know its rotated 3.46 times. Do I have to bust out trig to figure it out? I dont think you can tell the difference between 3.46 and 3.73.
If you cant tell the difference between those two, then you arent paying attention. If you mark the driveshaft that 1/4 turn/90 degree difference is easy to spot.
Originally posted by Wh33lhop View PostYou can't tell the difference between three and a half and three and 3/4?
Originally posted by SamE30e View PostThere is the easy way...
Step by Step instructions by Sam
1. Goto a empty straight road
2. Look around for police
3. Stop vehicle
4. Depress the clutch pedal
5. Select first gear
6. Bring the engine speed to 5000rpm
7. Rapidly release the clutch pedal while simultaniously going WOT and hold for 2 Mississippi's, (The vehicle will lunge forward at a fast rate (Unless you're driving a 318i or ETA)
8. Stop vehicle
9. Get out of vehicle
10. If there are 2 rubber marks you have a LSD, if only 1, you have a Open diff or a POSLSD.
Sam
///B///M///W///
