Wheel bearing hell f**k my life
  • 416stroker
    • May 2008
    • 2448
    Im doing rear axles on my car so I have a press at the shop at my dads work. I pressed the old one out and pressed the new one in. No problems.
    when I got to put the axle in It almost made it all the way threw so I figured I would give it a few wacks from my 3lb single jack only to have the hup pop put of the bearing with the outer race attached any one have this happen I think its because I got this bearing from kragen. So Im pretty sure I got a defective bearing.
    MfrCode=SKF&MfrPartNumber=GRW231&PartType=186&PTSe t=A
    Nothing can ever go easy. The first one went on fine.
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
  • Mitch M
    • 881
    They will blame the 3 lb hammer and probably make u buy a new one. Clean the splines on the hub as well as the CV, add a little grease and it should slide on w/o much effort.
    Good luck.
    • 416stroker
      • May 2008
      • 2448
      Good luck.
      Ive cleaned up the half shafts and the hub it was greased. I juts pushed the outer race off by hand. Im pissed right now. I hate kragen
      84 318I Delphin RIP
      89 325 Alpineweiss
      • Julien
        • 7472
        hub has a C clip holding it in, no?
        Build Threads:
        • straight6pwr
          • Sep 2004
          • 3450
          the only thing you should ever buy from domestic auto parts stores are things like wiper blades, cleaning supplies, and tail light bulbs. i would never trust any real parts to last, let alone fit the car.
          • 416stroker
            • May 2008
            • 2448
            yes. The c clip has nothing to do with the inner race.
            84 318I Delphin RIP
            89 325 Alpineweiss
            • 416stroker
              • May 2008
              • 2448
              I know the pilot bearing I got for my old m20 was too small for the crank.
              The hub fits so lose in the bearing its a joke I can push it half way on by hand. I barely tapped the half shaf with the axle.
              I trust NAPA. But they had 4 day wait kragen had them in stock now I have to wait for the new one to come.
              84 318I Delphin RIP
              89 325 Alpineweiss
              • Jean
                • 18228
                Next time pull the trailing arm, and bring it to Riebes shop with a new wheel bearing. No joke, they charged me $40-60 per trailing arm and it was done.
                • 416stroker
                  • May 2008
                  • 2448
                  I pulled the trailing arm and used a press. I have all the right tools at my dads work.
                  84 318I Delphin RIP
                  89 325 Alpineweiss
                  • Jean
                    • 18228
                    You failed then lol j/k
                    How much were kragen bearings? I remember they were $28 from autohausaz.
                    • 416stroker
                      • May 2008
                      • 2448
                      83.99+tax but I need them today.
                      84 318I Delphin RIP
                      89 325 Alpineweiss
                      • Jean
                        • 18228
                        Damn! ... I think you could have ordered one from autohaus with next day shipping and still come out ahead :) Or local bmw dealer even lol. Kragen FTL.
                        • b*saint
                          • 3794
                          Ok if the bearing is indead bad, bring the bearing to a local bearing store. They will match the numbers. Go with NTN or Timken. FAG are overpriced german bearings and NTN are what ZF uses in the BMW diffs anyways. Look how long THOSE bearings last.
                          Ma che cazzo state dicendo? :|
                          • txtorquemade
                            • 1758
                            FAG are good bearings and not badly priced at 63.00
                            sigpic 1987 325is
                            • SamE30e
                              • Sep 2007
                              • 4319
                              You pressed it in from the inner race didn't you? haha
                              1985 325e 2.8 Turbo VEMS
