Mega Squirt question
  • der affe
    Technical
    • Dec 2005
    • 8452
    i went IAT hunting today and grabbed a bunch of different ones...all GM
    so which one am i supposed to use with MS?
    top view
    the 2 on the left were outof the intake manifold
    the three on the right were form the intake tract, elbow, etc the one on the far right was from the SC'ed regal that i got my 5th gen M90 from. i am going back tomarrow to get the one out of the intake mani on the regal i have the pigtails for all of them.
    so which type do you run with MS?
    i will eventually be running the S/C on the car so if there is a boosted preference i will go with that one.
    i also picked up more coil packs for wasted spark.
    GM MAP sensor
    E36 TPS
    GM wide band 02 sensor
    what GM coolant temp sendor and pigtail am i looking for?
    thanks for the help,
    Greg
  • whodwho
    • Jun 2008
    • 1547
    The second one from the left is the more common one used. You can probably use any of them if you want to test the values. For boosted applications the open element sensor will respond quicker.
    For the CLT you can also just use the stock Bosch sensor.
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • shiboujin
      • Feb 2006
      • 2791
      You don't need a MAP sensor, MS has one built in. I personally use the second one from the left. Have had no problems with it. Altho I'm fairly sure any of those will work.
      the coolant sensor you want is Part # MSD-2310
      • der affe
        Technical
        • Dec 2005
        • 8452
        i am looking ar the P&P kit from DIYAUTOTUNE, they told me that with the ITB's i will need to make a signal box and run the line from all the ITB's (vac) into the box and connect thew sensor to that. did i miss something. IIRC it is MS2 v 3.2 or something like that.
        • shiboujin
          • Feb 2006
          • 2791
          MS has the map sensor port on the box itself. you want to take each ITB, link them all to one "box" then link that box to the MS itself. At least thats how I think its done. You shouldn't need a second sensor unless youre doing baro correction.
            • 34844
            top view
            GM MAP sensor
            E36 TPS
            Greg
            I can't see which one you posted, but use the one with an open element if you have one.
            also, I'd suggest using the stock E30 coolant sensor.
            you don't need the GM map sensor (MS has one built in) and the WB seosnory by itself won't help you because you need an controller anyway (AEM, Innovate, etc. all sell controllers with sensors for about $200).
            • der affe
              Technical
              • Dec 2005
              • 8452
              there is actually several with the open elemeny, but only one with the open element and threads so i will go with that one.
              i have an LC-1 on the way, but i this is the same o2 they use (different connector though) so it is a spare
              • der affe
                Technical
                • Dec 2005
                • 8452
                the SC'ed Regal i pulled the charger from actually had 2 one in the air box (open element, but popped in) and one in the intake manifold (brass and screwed in) that kind of threw me for a loop that it would have an up stream and down stream sensor. my friend is going to give what ever sensor i need to use free (he is a GM tech) from his spares. it is really just a matter of finding the stuff that will work first.
                at least they did not cost me anything. $5 each for 3 sets of coil packs, then i broke out with the sendors and she said "what are those?" sensors i told her "take 'em. that will be $17. 58 please"
                  • 34844
                  dude, that's cheap for coils. you get the bases too? doesn't hurt to have the sensors either, even if you end up not using them.
                  the regal sounds like it had a pretty elaborate IAT setup, one probably measured intake air, the solid one was measuring intake manifold temp. no idea what the third one was for!
                  did you get the charger too? I've thought about doing something like an M90. I already have everything setup, FI just seems like a natural progression from here..
                    • 34844
                    you run a vac line from each TB to a vacuum canister, and then a single vac line from the canister to MS.
                    the new 2.1.1 beta has much improved MAP sampling BTW. it elimnated about 95% of the noise from my engine without hurting response (in fact, i was able to decrease the lag factor all the way to 90%).
                    • diegom6
                      • 4447
                      Second from left.
                      Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
                      • tjts1
                        • May 2007
                        • 1851
                        The last 2 on the right.
                        • der affe
                          Technical
                          • Dec 2005
                          • 8452
                          there was just the 2 sensors on the regal one for incomming air and one for mani temp.
                          i have bases, coils, pigtails, everything for $5 each. i am thinking about cleaning them out at that price.
                          i picked up the charger too, but it was missing the snout, no biggie though, it is a spare, i am going to go by the core guys shop to pick up a few more tomarrow.
                          i used my bargining skills and got it for $25 too.
                          if you want to go SC, i would suggest that you go for a 5th gen M-90. they are the latest and have a built in by pass valve for better milage under low vac or off boost. don't worry about the rotor coating, it is usually comming off and is just teflon paint. if you completely remove it it will make no difference and not effect your clearences.
                          on my set up i am going to blow throught the dbilas insted of a single TB and run a water to air intercooler. i am using a 4 cyl mustang crank pulley too.
                            • 34844
                            $5 is a great price, my coils were NOS for about $50 with bases and wires. Still beats $80+ for a cap and rotor!
                              • 34844
                              oh now that I can see the pic, I'm using the second one from the left.
