water pump help
  • Good & Tight
    • Apr 2004
    • 2057
    water pump help
    Guys I'm in the middle of 24v swap and need some clearance for the electric fan, so I need to cut the front of the pump off. Just threaded part, but will it fall apart, it looks like it will.
    maybe someone with an old pump can cut the tip off and see what happens..???
    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
    ____________________________
    E-mail Panayiotisx2@gmail.com
    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
  • 416stroker
    • May 2008
    • 2448
    It shouldn't if you go easy on or with a band saw. Just by looking at my spare pump
    84 318I Delphin RIP
    87 325IS delphin 24v Sold
    89 325 Alpineweiss
    • Good & Tight
      • Apr 2004
      • 2057
      It looks like it's pressed on the shaft so that's what's getting me worried. If I cut it off, will the flange were the pulley bolts on will fly off if it's compromised in any way. It's a brand new pump, damn and I threw the old one away, figures I never throw shit away but now I need it to hack it up.
      • iamsam
        • Jun 2008
        • 176
        put a pusher fan on the front of the rad unless you still have the AC in.
        • 416stroker
          • May 2008
          • 2448
          That could happen. I think youd have to be verry careful and cut it at the band saws slowest speed. I dont have access to good one at the moment. I wouldnt cut it with anything else though.
          84 318I Delphin RIP
          89 325 Alpineweiss
          • Good & Tight
            • Apr 2004
            • 2057
            Still have a/c.
            • Good & Tight
              • Apr 2004
              • 2057
              I might pull the pump off, cut it, and then weld it in a few spots.
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                The bearing race in the housing is farther back, you can cut off the threads. It won't come apart.
                (judging from the innards of broken pumps I've seen in the P'n'P.)
