Need a clutch! Suggestions????Please help!!
  • ediaz029
    • 75
    So I replaced my lsd and now its the clutch too so I need a complete kit. Any suggestions as to wich one for a dd/track car just sometin so I can get to school and back without killin my leg but also giving me better than stock. Anything else I should upgrade/replace while I'm there?
    Thanks so much any input is welcome!!
  • ediaz029
    • 75
    anyone???? I really need to figure this out
    • SamE30e
      • Sep 2007
      • 4319
      Just get a OE replacement.
      1985 325e 2.8 Turbo VEMS
      • ediaz029
        • 75
        I want to upgrade while Its out
        • White325is
          • Oct 2006
          • 5947
          What are you puting it in? 325e 325i? A stock clutch can hold very well.
          • ediaz029
            • 75
            1991 318is
            • White325is
              • Oct 2006
              • 5947
              M20 single mass flywheel and clutch will be a upgrade.
              • BlackSpeed66
                • Apr 2008
                • 624
                Why do you feel you need to upgrade? Unless you're running some crazy turbo setup or an engine swap, a stock clutch will work just fine. I'm sure plenty of folks on here that DD, auto-x, or track their cars use the OE clutch as well. I do.
                -Geno
                '87 325is (s52'd)
                '95 525iT
                '95 Jaguar XJR-6
                '02 Range Rover 4.6 HSE
                '98 Disco 1
                • ediaz029
                  • 75
                  I already have an m20 flywheel so does the m20 clutch disks, pressure plate and throw bearing bolt right on?
                  • ediaz029
                    • 75
                    and its not that I feel the need to upgrade I just wasnt sure what my best option was
                    • White325is
                      • Oct 2006
                      • 5947
                      Yeah its direct swap. People use the M20 single mass and clutch for M50 swaps along with the 240 trans. Everyone says you need a euro 323 TO bearing but when I searched the M20 single mass and the euro 323 have the same part number on realoem.com
                      • quickervicar
                        • 1197
                        PM sent
                        • e30fish
                          • Oct 2009
                          • 332
                          just curious, but does the new flywheel have to be balance matched to the old one?
