Any idea why the reverse lights wont work on either side? all light bulbs are fully functional just no lights for when I'm in reverse..
no reverse lights?
no reverse lights?
Check out my stuff for salehttp://www.r3vlimited.com/board/show...=1#post1600997
anything you need I can find just shoot a PMTags: None
Under the shift boot are the wires for the reverse light switch. If I remember correctly, they are green wires, unplugged them and hook a jumper wire to the two wires running toward the back of the car and check to see if the lights turn on. If so, it's the switch, it's an easy fix, this is how I found to check it out, worked for me. Changed the switch and everything is working now.
