Clunking sound
  • DanMan68
    • 204
    Clunking sound
    When I let out the clutch on my car I sometimes hear a clunking sound. I haven't had a chance to look at the drivetrain, but what do you think is the problem? U-joints, Diff, axles? From how the clutch feels and the sound, I can tell there is a bit of slack somewhere in the car.
  • beybedba
    • 517
    i have the same issue on my car. :(
    • dreamchasin
      • 3892
      is it when you take your car out of first and you hear a little clunk then a tiny rattle?
      90 325is alpine2 m50b25 becoming a dorifto car.
      • DanMan68
        • 204
        humm... not sure. I will have to listen more closely next time I drive it. But I can say that it is more of a combined feeling/sound where I can hear/feel the slack being taken up by the drivetrain. It does seem worse with the lower gears though.
        • dreamchasin
          • 3892
          just asking because my car did that. if i had it in first and took it out, let the clutch out there was a little clunk and then a little rattling noise. never happened in 2nd, 3rd, 4th, or 5th, or reverse.
          • beybedba
            • 517
            mine does this
            • D-rock
              • 714
              Mine did this. It was the rear axel. If that helps anyone.
              • e30trooper
                • 11576
                mines doing that also, found out the inside CV boots are trashed. only happens in 1st or 2nd letting on the clutch at slow speeds.
                • e30:)
                  • 728
                  probably the csb if you here it thumping right next you thats your best bet
                  • EricT
                    • 702
                    Mine makes this odd "snap" followed by a rattle......just won a new 87,000 mile trans on ebay...going to pick it up this afternoon and have a set of axles on the way. I know my trans is housed tho and my axles have slop in them. Also rattles while I let it warm up in the morning when in neutral with the clutch let out. I believe they call this the "getrag rattle". If I remember right, I read somewhere this means your input bearings or something along those lines are garbage.....:)
                    BUT THIS!!!!! http://www.r3vlimited.com/board/showthread.php?t=194272
                    • LosBemmer
                      • 65
                      Isn't why they are called CLUNKERS?????
                      • DanMan68
                        • 204
                        I dont want my car to clunk lol, it makes me nervous to drive it hard and also makes it hard to drive smoothly.
                        There is no rattle, just a clunking/faint bang when I let out the clutch. Also if I am coasting along and apply the gas quickly it makes the same sound.
                        • DanMan68
                          • 204
                          • txtorquemade
                            • 1758
                            Guibo
                            u joints
                            csb
                            or input bearing
                            Take your pick
                            sigpic 1987 325is
                            • noE30
                              • Jun 2008
                              • 2260
                              this happens to me when I'm in reverse, as soon as I push the clutch in I hear a few clunks coming from the rear.
                              Flickr
                              @michael.colby on Instagram
                              "All he needed was a wheel in his hand and four on the road"
