Warm (not hot) air from vent.
  • graphikg
    • Jan 2008
    • 1614
    My heater only lets out warm air when at full heat setting. I dont get it. Is my heater core plugged or what? Its not leaking through the firewall thats for sure.
  • ethree
    • Aug 2007
    • 1216
    It's probably the valve. Have fun! You should probably replace the lines that run through the firewall while you're there, they get corroded and pitted and don't seal well.
    • graphikg
      • Jan 2008
      • 1614
      know of any writeup or anything? Hey, youre in sunnyvale? Where do you go for meets etc. I am in gilroy.
      • mikeedler
        • 6707
        haha... my "winter car"-- vert is the same way-- and only blows cold air out of the vents in the dash-- first piece of crap e30 that has had bad heat I have ever owned.-- I think I am going to reg. my e28 and drive it throught the winter!
        • Super Sedan
          • Feb 2006
          • 551
          Thermostat?
          • Simon S
            • Oct 2004
            • 3758
            Originally posted by Super Sedan
            Thermostat?
            good call
            eliminate the simple shit first.
            -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
            • e30frosh
              • Dec 2004
              • 2170
              Thermostat?
              Ditto
              Every day I wake up we drink a lot of coffee and watch the CNN
              Every day I wake up to a bowl of clover honey and let the locusts fly in.
              Lobsterbacks attack the town again
              Wrap all my things in aluminum
              Beams of darkness streak across the sky
              Pink rays from the ancient satellite
              Every time I look out my window same three dogs looking back at me.
              Every time I open my windows cranes fly in to terrorize me.
              • graphikg
                • Jan 2008
                • 1614
                Switched out thermostat and its the same. Thats the first thing I did. Sorry about not mentioning that.
                • Naplm00
                  • Nov 2008
                  • 1573
                  an easy way to tell if you HC is clogged is grab the "return" hose from the HC outlet. If it is the same temp as the inlet hose, your HC is not clogged.
                  If its cold or not even close to the same temp, you either have a clogged HC or bad secondary thermostat.
                  Its a bitch to get to and replacing the hoses is a pain. I did all of mine when the engine was off the mounts and pulled forward.
                  88 325ic ~~~> Rusty and ugly
                  85 E ~~~> RIP
                  • xLibelle
                    • Aug 2004
                    • 2673
                    ventilation direction baffle might not full close off the cold air. (something to think about)
                    • Moto-Mucci
                      • 2058
                      in on this. i've got the same issue i'm trying to resolve
                      • graphikg
                        • Jan 2008
                        • 1614
                        do you have a stock m20 or motor swap? Just curious cuz my prob started happening shortly after the swap. It may be a reason for the issue or not.
                        • Moto-Mucci
                          • 2058
                          stock but swapped M20. My problem started after my HVAC panel got torn apart from a break in.
                          • graphikg
                            • Jan 2008
                            • 1614
                            It could be what a few others have been telling me then... Heater valve. The thing is, I have no idea on how to fix it.
                            • Moto-Mucci
                              • 2058
                              I plan on tearing everything apart soon so I'll let you know if I find/fix it.
